Grease Gun/Setup for ER PolyBronze Bushings
I seem to be having an issue greasing the rear PB bushings. Greasing the inner nipple (the one closest to the car body) is impossible due to lack of clearance. Luckily (or unluckily), my 30 year old hand-cranked grease gun died on me after 5 minutes of attempt; I think the rubber stem finally cracked. BTW, my dead unit is the 'needle' type.
What kind of grease gun/setup do you guys have to access the inner nipple?
Thanks a mucho.
Old 02-20-2007, 09:36 PM
don911's Avatar
I'm just using a gun with a flex line. Is your fitting centered in the bushing? One of mine isn't centered as well as it could be so that one is a little tight but I was still able to hook up to it.
Don
24 Cayman GTS - GT Silver
23 Cayman GTS - Arctic Grey - Sold
97 993 Coupe - Arctic/Black - Sold
13 991 Coupe - Platinum/Black - Sold, 87 911 Coupe - Venetian Blue
Old 02-20-2007, 10:22 PM
scottb's Avatar
Have you tried a right angle fitting for your grease gun?
Or, how about a swivel fitting?
Both are available at Harbor Freight for just a few bucks. Kragen.com has them also, but they're more expensive.
Combined with a flexible hose, one of these might solve your problem.
Good luck!
1984 Targa
Old 02-20-2007, 11:24 PM
Johnb911's Avatar
Could someone list all the grease points on an SC.
JOHN
79 EURO SC
"24 Years Later - The Dream Came True"
Old 02-20-2007, 11:47 PM
One of my rear nipples gave me a bit of trouble and I found that the right angle fitting (on a flex line) worked better in my situation.
Old 02-21-2007, 05:28 AM
swa911's Avatar
Use a flush type grease fitting on your gun. It is a little tricky till you get the hang of it. Just put the tip of the fitting in the end of the zerk and press hard. It works.
1978 911SC #737 "D" Class Club Racer
Old 02-21-2007, 06:37 AM
GothingNC's Avatar
Is there a preferred grease to use?
I have Poly bushings up front and Neatrix for the rears.
Thanks !
John D.
82 911 SC Targa-Rosewood
2012 Golf TDI
Old 02-21-2007, 09:17 AM
Thanks !
I use Redline on my poly-bronze bearings (it's the grease I keep on hand), but any good grease should suffice imo.
Old 02-21-2007, 09:41 AM
You can also attach a needle fitting to your gun and then slip the needle inside of the zirk fitting. A little on the messy side, but at least it gets in there.
Scott, thanks for the info on tips. For what it's worth, I have been into at least three different Kragens asking about alternate fittings and they all said they had no clue. YMMV of course.
HF here I come!
-Chris
1987 Guards Red Targa (sold)
2006 Toyota Tundra DC 4x4, the "man-e-van"
1998 CR500
Well on the fringe......
Old 02-21-2007, 10:13 AM
TWork's Avatar
Interesting. I'm having the exact same problem. The car's not on the road yet so I have some time. I'll have to pick up a right hand fitting.
'73 Targa
Old 02-21-2007, 10:26 AM
pmajka's Avatar
Poly Bronze on a street car?
Yes or No
Have you ever felt suffocated while watching the Oxygen Channel?
People with excuses fail. As soon as I OK my actions with an excuse, I cease bettering myself.
88 Carrera
Old 02-21-2007, 10:42 AM
Yes, absolutely!
Old 02-21-2007, 10:47 AM
goat's Avatar
Yes or No
Yes!
I don't know what grease gun I have but it is very old. May have to try the swivel fitting myself.
Tim.
1988 911 Carrera. Silver.
1973 914 Metalic Blue.
2012 Cayenne S
Old 02-21-2007, 10:56 AM
Scott,
Do you have the PB bushings? I am soliciting for 'actual experiences.' Those fittings are also at PepBoys. I want to make sure that what I buy will work.
I'll stop by HF so that if it does not work, it would be less $$ wasted.
Old 02-21-2007, 04:57 PM
Keith,
The right-angle one was the one I was eyeing as the best candidate. Did you have clearance issue? Can it be cut shorter, if needed?
Old 02-21-2007, 04:59 PM
Danimal16's Avatar
I wonder if Chuck has any insight on this one? If anyone can figure it out, well rumor has it he's come up with a few inovations???
Chuck, where are you?
Dan
Old 02-22-2007, 08:54 AM
Chuck Moreland's Avatar
I use a regular, straight, rigid gun tip. I did touch the side of the tip to a grinder to make it easier to fit next to the cover plate - but that issue was specific to the thickness of my tip.
I have two grease guns. A man-size one that takes the big grease cartridges, and a smaller one that most home mechanics would use.
I use the smaller one and don't have any problems getting the gun in place.
Chuck Moreland - elephantracing.com - vonnen.com
Old 02-22-2007, 10:52 AM
Danimal16's Avatar
Forgive me, but I can't resist, SO SIZE DOES MATTER!
Dan
Old 02-22-2007, 10:54 AM
Diss Member
Quicksilver's Avatar
I use a plain straight grease gun for mine. Do you have a picture? I'm wondering if your zerks could have been placed better or not. (I guess by now that the point is moot...)
- "Speed kills! How fast do you want to go?" - anon.
- "If More is better then Too Much is just right!!!" - Mad Mac Durgeloh
Wayne - 87 Carrera coupe -> The pooch.
Old 02-22-2007, 11:40 AM
Me like track days
Craig 930 RS's Avatar
Chuck -
Related to this - my A-arm (front, of course) nipples have self-rotated upwards to the point where I cannot get any grease gun on them.
What is the proper way to remedy this?
- Craig 3.4L, SC heads, 964 cams, B&B headers, K27 HF ZC turbo, Ruf IC. WUR & RPM switch, IA fuel head, Zork, G50/50 5 speed. 438 RWHP / 413 RWTQ -
"930 is the wild slut you sleep with who tries to kill you every time you "get it on" - Quote by Gabe
Movie: 930 on the dyno
Old 02-22-2007, 11:56 AM
