Guest
Posts: n/a
Engine type number?
Got a quick one that anyone out there may be able to help mem with:
I'm currently in the process of buying a new engine, and came across what is supposed to be a -83 SC-engine yesterday. Since it is sitting in an older car, I need to know the engine type number to verify that it IS an -83 engine, and not -say- one of the earlier SC-engines. ![]() I know of THREE different type numbers that are supposed to be for these engines; 930/04, 930/07 and 930/16. Fist of all -are these the correct type numbers, and which one of these is the -83 engine? (It's a euro spec engine, if that matters) Thanks for any help I may get! ------------------ |
Guest
Posts: n/a
Bo
Can you get the whole engine number? That would make identification easier. Right now I can't remember. I'll check when I get home though. |
Guest
Posts: n/a
04=78/79, 3.0
07=80, 3.0 16=81-83, 3.0 BTW, theses are ALL USA spec engines... A euro spec is a 930/10 [This message has been edited by mikez (edited 12-20-2000).] |
Guest
Posts: n/a
You should really get the engine number that is stamped on the actual engine you are purchasing. That way, you know exactly what you are buying. Euro-spec does make a difference.
930/04=78/79, 3.0 8.5:1 180 hp 930/07=80, 3.0 9.3:1 180 hp 930/16=81-83, 3.0 9.3:1 180hp As mikez said, the euro spec engine is 930/10 81-83 3.0 RoW 9.8:1 204hp |
Guest
Posts: n/a
Where do you find the engine #??
Pete ------------------ www.geocities.com/pcafaro2000/carrera30.html |
Guest
Posts: n/a
The engine SERIAL number is on the vertical fin near the oil sender. The engine TYPE # is on the horizontal surface behind it.
Guest
Posts: n/a
Bo!
My Porsche family tree says: 1983 911SC Engine S/N 64D0001-64D5651 The engine number should fall within this range. Huey581 86' 911 Cab |
Guest
Posts: n/a
Great!
I'll go check out the engine, to see if the numbers match with the year. Thanks all! Bo ![]() ------------------ |
Guest
Posts: n/a
930/03 is the euro 180 hp 1978/79 motor.
930/07 is the euro 188 hp 1980 motor. 930/10 is the euro 204 hp 1981/83 motor. The year code is 8 for 78, 9 for 79, A for 80 and B for 81 etc. |
Guest
Posts: n/a
How does 930/02 translate???
Pete 77'Carrera3.0 ------------------ www.geocities.com/pcafaro2000/carrera30.html |
Guest
Posts: n/a
Pete,
930/02 = R.O.W. Carrera 3.0 -- 200 hp DIN @ 6000 rpm 76/77 CIS ------------------ Warren Hall 1973 911S Targa |
Guest
Posts: n/a
Thanks Warren!! Just wanted to make sure all was well with my baby!!
