azporsche911.com
Hoffmanmotors's Avatar
Stupid question, what is considered proper running temp?
Just wondering, mine floats between 120 and 180. I know i i know im a dumb NEWB! lol
Jeff Hoffman (Son)
Tom Hoffman (Father)
79 911sc ROW guards red coupe
father son project.
Old 03-03-2007, 03:01 PM
19 years and 17k posts...
azasadny's Avatar
My '74 runs around 190-200 degrees during the MI summers and it has the external Carrera-style oil cooler. Your ambient temps are quite a bit higher than ours so I would expect your temps to be a little higher. Of course my temps are what the gauge is showing and I'm not sure how accurate the gauge is...
Art Zasadny
Learning the bass guitar
www.ford.com
Old 03-03-2007, 03:06 PM
azporsche911.com
I was thinking the same about how accurate my guage is. Any AZ pelicans wanna ring in??
-Jeff
Jeff Hoffman (Son)
father son project.
Old 03-03-2007, 03:55 PM
Not Arizona, but close by. My 75 ran between around 190 here in So. Cal. with the stock cooler, except on the hot summer/santa anna days at freeway speeds. Then it would pass 210, but never exceeded 230. I now have an external cooler w/o fan and rarely exceed 180. Again, relying on the gauge. Best investment I made!
Larry
L.J.
Recovering Porsche-holic
Gave up trying to stay clean
Stabilized on a Pelican I.V. drip
Old 03-03-2007, 05:49 PM
Porsche considers 180 degrees F. to be the optimum "running temp." This, give or take a few, is where the thermostat opens in order to send oil to the front cooler in order to maintain 180. This is not to say that there's anything wrong with temperatures above 180--certainly any hard-used track car would see 200+, though 250 seems to be the maximum long-term limit--but cruising temps below 180 are considered by Porsche to be "cool," and we're not talkin' style.
If you drive a 911 "normally," i.e. nothing extreme in terms of pounding it, nothing extreme in terms of OAT, it is designed to stay at around 180.
Stephan Wilkinson
'83 911SC Gold-Plated Porsche
'04 replacement Boxster
Old 03-03-2007, 06:08 PM
110F desert, consistent 80mph, fender cooler, engine ran 200-210F. If i increased speed temp would climb.
Normal summer heat through Rocky Mt foothills is about 180-190F at 80mph.
Winter running is 170-180.
imo... if your at the margin with oil temps a single CHT will give you a heads up a few minutes in advance of a rise in oil temps. The biggest pia is bringing down the temps from excessive. Riding into the mts to hit la la land from the north on I-5 is a good example of keeping a heads up during a hot summer day. 5th gear will see cyl head temps rising so it's time to ride 4th gear before oil temps rise. Riding 4th at 3.5-3.8k rpm creates more fan cooling, less ring & bearing load, no wear on engine, and lower CHT.
being negligent riding up Independence Pass in Co during hot summer may generate very high CHT way before your oil temps lets you know what's happening. Just keep the revs up and don't lug for any reason.
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 03-03-2007, 06:30 PM
In the summer , mine runs around the 9 o'clock temp position,
winter, around 7-8 o'clock. Engine seems to like cooler weather.
'03 Boxster *****
'82 911SC ****
'98 BMW Z3 **
'87 300Z ***
'80 BMW 320i ****
Old 03-03-2007, 06:33 PM
Dunno what the o'clock positions equate to any more, I have a numerical oil-temp gauge. But I think 180 is about eight o'clock, nine is maybe 200. So you're doing fine. The Germans don't know from summer, US-wise.
Stephan Wilkinson
Old 03-03-2007, 06:42 PM
charleskieffner's Avatar
to get any 911 to run at 180 degrees in 115 plus temps is simply not possible w/out a fender and front oil cooler. since you live here and want to drive year round.........dump the bucks for oil cooler and lines. go w/a setrab for the front. worth its weight in gold. unless you have deep pockets for a new engine when stuck on one of the freeways.
doing 65mph on 118 degree day w/ac on 190. degrees. the best it will ever be. at the track in april on 85 degree day 200-210 degrees driving the snot out of it!
Old 03-03-2007, 08:05 PM
steve what exactly did you mean by the below 180 running temps. I typicallt run about midway between 120 and 180 on cold days 30 to 40 degrees. I have the front oil cooler and on warm days it runs at about 175 to 180. car runs great so I just assumed that was the ambient temp,but is there something I should check?
getting the jump on my mid-life crisis
Old 03-05-2007, 08:41 PM
Troy, I'm not entirely sure what you're asking. Your temps sound fine. When I said below-180 is "cool," I didn't mean it was particularly bad. Obviously I wouldn't drive five miles a day at a well-below-180 temp, but I assume that's not what you're saying. Warm days at 175 to 180 sounds like the thermostat is probably opening and your front cooler is stabilizing the temps at that number, which is exactly as it should be.
Stephan Wilkinson
Old 03-06-2007, 05:22 AM
Re: running cooler, FYI. I am running a 79 SC coupe with a rear 964 spoiler . When the spoiler is up/open, the engine runs ,maybe 10-20 deg cooler .Very suprizing and welcomed effect of bastardizing my car.
i also have the serpintine cooler and was going to upgrade it to a carrera cooler, but now I dont see the need to upgrade. .
Cant believe the difference.
HB Kramer
(4 sneaks and 6 airheads): 79 911SC Coupe (sunroof delete)
(2 sneaks and 2 airheads): BMWS: R12GS(a) R90S, and some old British iron as well.
Old 03-06-2007, 05:56 AM
Elu Elu is offline
Elu's Avatar
Send a message via Yahoo to Elu
Well, as far as what I am used to, and I live in New Mexico, my 74 911 runs at about 230 to 250 on 100 + degree days. In the winter months my car runs at about 180 to 210. I have an external oil cooler and I run the AC all the time. I'm not sure you can compare the temps to places like Oregon, New York or any place other than the SW desert. Dry heat affects cars much different than places with a little moisture in the air.
Come check out my new stuff....you know you want to.
www.myspace.com/elu
Elu - the sensual nature of humanity
Available on Eroica Records
The new album is now available.
Old 03-06-2007, 06:54 AM
You need a bigger oil cooler.
Stephan Wilkinson
Old 03-06-2007, 06:57 AM
Elu Elu is offline
Elu's Avatar
Hey Steve! I'm not convinced a larger oil cooler will help the issue. When the air temps coming off the roads is 120 plus degrees, how are you going to get cooler temps from a cooler located close to the pavement? We don't get an evaporative cooling effect here in the SW. It would seem that the only viable option is to add a fan to the cooler. And that will probably only give you 5 degrees. I'd sure love to hear from other Porsche owners in AZ and NM. I'm thinking his car will run hotter in the summer months than it does now. Especially in AZ.
www.myspace.com/elu
Old 03-06-2007, 07:09 AM
Somatic Negative Optimist
Gunter's Avatar
Cool
Add the oilfilter cooler?
With 230-250 degrees in the summer, I would seriously try to bring that down.
More ventilation to a bigger cooler?
Installing a fan?
1980 Carrerarized SC with SS 3.2, LSD & Extras. SOLD!
1995 seafoam-green 993 C2, LSD, Sport seats.
Abstract Darwin Ipso Facto: "Life is evolutionary random and has no meaning as evidenced by 7 Billion paranoid talking monkeys with super-inflated egos and matching vanity worshipping illusionary Gods and Saviors ".
Old 03-06-2007, 09:24 AM
GrantG's Avatar
Actually, dry heat is not your problem. It's the thinner air of high altitude environments. The thin air cools much less effectively. I have an RSR-style front spoiler cooler and it helps tremendously. Rarely get over 210F buzzing around the track in the Summer at engine speeds over 7,500 rpm (and 190F on the track in the cooler months)...
2022 GT3 Manual, 73 Carrera RS 2.9 Twin-Plug MFI Carbon Fiber Replica
Former: 18 GT3 Manual,16 Cayman GT4, 73 911S, Two 951S's, 996 C2, 993 C2, BMW 635CSi Euro, Ferrari 550 Maranello, 06 Evo IX w/ many mods
Old 03-06-2007, 10:09 AM
No oil cooler on my 2.4. I run 180 all of the time in Florida. At Sebring I can get to 210 if I'm running fast.
Richard
Old 03-06-2007, 10:23 AM
If I get behind one of those 35 mph speed limit types with auto trans, the temp gauge will creep up a bit.
Last summer, I got caught in an uphill line of classic cars waiting (too long) to get assigned spaces at a nearby Museum car show The SC didn't like it--no overheating, mind you--but the gauge did move up a bit. The "volunteers" at this show moving traffic left something to be desired.
'03 Boxster *****
'82 911SC ****
'98 BMW Z3 **
'87 300Z ***
'80 BMW 320i ****
Old 03-06-2007, 12:21 PM
Elu Elu is offline
Elu's Avatar
Grant,
Do you have a part or model number for that rsr cooler? I'd like to check it out.
www.myspace.com/elu
Old 03-06-2007, 12:44 PM
