Juggino's Avatar
Send a message via AIM to Juggino
H1 lens spider web, whats with all these clips?
Today, I did a little lighting upgrade to my 1978 SC that has H1 headlights. I went from the 55w low beams to the 100w PIAA super bright bulbs including the relay kit. I thought that while I had the cans out that I would change out the lenses as well. Upon examination of the assembly it seems like there are 1 gazzilion single clips that hold the lens in. Is that correct? Does anyone have experience with this? Any constructive input is welcome....
Old 06-08-2013, 03:50 PM
Member 911 Anonymous
DRACO A5OG's Avatar
They keep the lens in place, they have to be evenly spread out when clipped in or place them back as OEM. I used one as a sample when I replaced my H1 lenses to the H4 lenses, no worries same pattern ___/___/
You also need ceramic sockets for those hot babies.
'85 Carrera Targa
PCA/POC
Old 06-08-2013, 05:16 PM
Juggino's Avatar
ceramic sockets for H1 bulbs? is there such a thing?
Old 06-09-2013, 05:23 PM
AutoBahned
RWebb's Avatar
he means for the wiring
what bulb kilowattage are you running?
Old 06-09-2013, 05:49 PM
DRACO A5OG's Avatar
Oops my bad, yes, I meant wiring, thicker gauged.
'85 Carrera Targa
PCA/POC
Old 06-09-2013, 06:55 PM
Juggino's Avatar
I replaced the stock 55w bulbs with 100w Piaa super bright. Installed the relay kit. The wiring for the high beam bulbs seem to be the same gauge as the low beams and they are 100w. In case you don't realize, the H1 setup uses separate bulbs. My thoughts are that its fine. Also asked several knowledgeable people and the general opinion is that only the relay kit is needed.
Old 06-09-2013, 07:44 PM
