-   -   changing rear trailing arms (http://forums.pelicanparts.com/porsche-911-technical-forum/333789-changing-rear-trailing-arms.html)
pinto096 03-05-2007 05:49 AM
going from an earlier 77 930 arm and brake set up to an 80 arm set up with the newer brake calipers question when removing these arms will the spring plates bounce in a dangerous position possibly severing a finger or this can be done with no effect on the spring plates? any info appreciated thks
tonythetarga 03-05-2007 06:05 AM
If you have the weight off the wheels you will be fine. If you unbolt the springplate from the arm while they carry no weight they will not be "sprung" or release any tension.
randywebb 03-05-2007 12:04 PM
take the sway bar loose too
pinto096 03-05-2007 12:40 PM
thanks fellas ill be tackling this project soon as the weather gets a tad bit warmer
