changing rear trailing arms
going from an earlier 77 930 arm and brake set up to an 80 arm set up with the newer brake calipers question when removing these arms will the spring plates bounce in a dangerous position possibly severing a finger or this can be done with no effect on the spring plates? any info appreciated thks
If you have the weight off the wheels you will be fine. If you unbolt the springplate from the arm while they carry no weight they will not be "sprung" or release any tension.
Tony G 2000 Boxster S |
take the sway bar loose too
"A man with his priorities so far out of whack doesn't deserve such a fine automobile." - Ferris Bueller's Day Off |
thanks fellas ill be tackling this project soon as the weather gets a tad bit warmer
