Green Skull 006
This can't be good.....
I found this washer stuck to the engine oil drain plug today. There were no metal shavings or anything else that looked odd. The washer is 18mm dia. with a 5mm dia. hole, it's about 1mm thick. It doesn't appear to be damaged or scratched at all. Any ideas? I'll be on the couch with a stiff drink.
S Reg 823 R Gruppe 246 1955 pre-A Carrera Speedster...x 1974 leichtbau..."Sascha" "It makes me sad. Our cars were meant to be driven, not polished" - Ferry Porsche while surveying a PCA Parade concours field. |
I wonder if someone dropped a valve cover washer in while doing a valve adjustment. Hmmm, But those are aluminum.........
Silver 1980SC Euro coupe |
Oh m'god!
The washer is the least of your problems. The bolt that let this loose is what you should be worried about. Just kidding. The ID looks like M6. The 18mm OD indicates it's a body washer of some sort, the type used to attach a bumper to a chassis support. I know of nothing inside the engine that normally uses this size washer (which isn't to say someone could have been thinking about using it once upon a time). I think it's one of those extras that happened to end up there. I wouldn't worry about it unless you also hear loud knocking noises. Sherwood |
Back in New England!
Sounds like something that fell in during a valve adjustment, from a source such as Sherwood stated. Its a great thing that you didn't find any shavings too.
-Matt
'78 RoW 911SC Targa converted to a '86-like 3.2L Cab (w/930 body & No A/C) Custom subframe integrated into AutoPower Half Cage, Euro Ride Height, Turbo Tie-Rods, WeltMeister Bump Steer Kit, Sway-Away 26mm Rear Torsion Bars, Koni Adjustable Shocks and Strut Inserts, Two Bar Rennline Strut Tower Brace, Poly Motor Mounts, WEVO Trans Mounts, Modified Conical K&N Intake, ER PB A-arm bushings and 17" CUP3 Wheels. Steve Wong Chip! |
Standard DIN 9021 oversize diameter M6 washer. Used on the engine tin in a few locations.
http://www.metricmcc.com/catalog/Ch2/2-233.pdf
Warren Hall, Jr. 1973 911S Targa ... 'Annie' 1968 340S Barracuda ... 'Rolling Thunder' |
19 years and 17k posts...
Man, you dodged a bullet there! Have a drink, say prayer of thanks and drive the car! (Oops, don't have the drink first!)
Art Zasadny 1974 Porsche 911 Targa "Helga" (Sold, back home in Germany) Learning the bass guitar Driving Ford company cars now... www.ford.com |
Registered abUser
Seek hypnosis to erase that washer from your mind.
Green Skull 006
Well I have to say that I feel much better now than I did a couple of hours ago. Thanks everyone for your replies.
I've been scouring my Bentley manual and Wayne's engine rebuild book for possible sources for the washer and ramifications. I was sure that the engine was going to have to come apart and the case split to find the bolt that lost the nut and washer. I was just about to go out to see if I could find a magnet on a hinged rod to fish aound to try and locate the nut. Forgive my ignorance, but I wouldn't have guessed that it's possible to drop something into the sump when adjusting the valves??
yea, if you were going to hear loud extention ladder collapsing noises, you'd have heard them by now!
Jake Gulick, Black Rock, CT. '73 yellow 911E , & 2003 BMW M3 Cab. Ex: 84 Mazda RX-7 SCCA racer. did ok with it, set some records, won some races, but it wore out, LOL[/B] |
Senior Member
It could have fallen into one of the oil return lines and found its way into the bottom of the case.
I'd rather find an arrant washer than shards of "piston ring soup" any day.
-- Chief Architect and Mastermind, SCWDP |
Jim,
Which drain plug – case or tank? If case, do you have a sump plate? How could the washer get inside the screen? If no sump plate, did the washer fit out the drain plug? I agree with the above, this isn’t an engine washer. It probably fell in somehow. A prudent move might be to fish around in the sump with a magnet. Even removing the oil return tubes can provide access. Hardware in the sump can’t do damage unless it gets to the scavenge pump or in the cam drive chains. The bottom of the case is well below the crankshaft and rods. A handful of hardware won’t do any damage. It is not unusual for an engine rebuild to find something in the bottom of the case. Most do no damage. Don’t worry about your find. Best, Grady
ANSWER PRICE LIST (as seen in someone's shop) Answers - - - - - - - - - - - - - - - - $0.75 Answers (requiring thought) - - - - $1.25 Answers (correct) - - - - - - - - - - $12.50 |
Green Skull 006
Grady, it was in the case, and the engine is a 3.2- so no plate. Yes, the washer was attached to the plug magnet and fit through the drain hole. I think that as I haven't refilled with oil yet, I will try to fish around with a magnet and see if I can "catch" anything else.
I can't tell you how relieved I am that this isn't turning into the scenario that I imagined when I first saw the washer on the plug magnet. My first thought was rod bolt failure until I looked at a picture in the manual and saw that wasn't possible, that's when I thought that I would probably get a definitive answer if I posted here.Thanks again to everyone who responded, this forum is great. You saved me from a series of sleepless nights.
Jim,
“You saved me from a series of sleepless nights.” Your post will save many from sleepless nights. BTW, I spent a couple of hours explaining 4-cam drive train to a youngster who has never seen one, (That is a 547 and later to the uninitiated). Best, Grady
There are _so_ many ways to drop things into a 911 engine you wouldn't believe it. Wedding rings, nipple rings, nuts, bolts, washers, you name it. Any time you're working on one, try to imagine where your cufflinks might go if they fell off, and stuff a rag in there.
Well, then there was the time I sucked six rags into the intake manifold when I forgot I'd used them...
Stephan Wilkinson '83 911SC Gold-Plated Porsche '04 replacement Boxster |
Registered abUser
Cufflinks and nipple rings. There's something I haven't worn in 30 years and something I'll never wear.
"....so_ many ways to drop things into a 911 engine ....wedding rings, nipple rings...."
I think I read the warning in the Factory Manual to ALWAYS remove nipple rings before servicing the engine.....
'83SC '76 911S - Sold. |
Registered abUser
Air Medal or two
small UFO
D troop 3/5 Air Cav,( Bastard CAV) and 162 Assult Helicopter Co- (Vultures) South of Saigon, U Minh Forest, Delta, and all parts in between |
Stephan,
You forgot bb's. Anyone have any shots of the infamous BB drop-into-intake manifold? Sherwood |
Diss Member
. . . I'm going to have to walk around and just shake it off. eek. . .
- "Speed kills! How fast do you want to go?" - anon. - "If More is better then Too Much is just right!!!" - Mad Mac Durgeloh -- Wayne - 87 Carrera coupe -> The pooch. |
