Anyone Running MS II V 3.0
Anyone running a MS II version 3.0 on their car? I am trying to complete one and have a few questions. Let me know, thanks.
I am in the process of installing mine. Engine rebuild still in progress so I haven't hooked it up yet.
Are you building the MS yourself or did you buy a completed one?
Steve are you running ignition off of it? Twin-Plug? Thanks Again.
I built the MS-II unit myself with continuous barometric correction (I live at 3000' in the Rockies) and knock sensing capability. I plan to twin plug but may run single plug for a while. My heads are currently being rebuilt and drilled out for twin plugs. I am also adding a cam sensor to my topend rebuild so I can go sequential injection when the new router board is available from B&G. The twin plug configuration will be parallel EDIS-6 units controlled by the MS-II at least for now. I may experiment with COP later.
I brought a twin-plugged 930 setup using MS II V 3.0 last year. Here's a post with some info and links to config files.
Thanks for the help, if anyone has the time to shoot me a pic or two (thanks to those who already PMed me) of thier completed circuit boards, that would really be helpful.
Thanks! |
| All times are GMT -8. The time now is 09:38 PM. |
