-   -   Anyone run 16 X 7 Fuchs front/rear - 911SC track application (http://forums.pelicanparts.com/porsche-911-technical-forum/334176-anyone-run-16-x-7-fuchs-front-rear-911sc-track-application.html)
ja78911sc 03-07-2007 06:18 AM
I recall reading a thread which a member used 16 x 7's on the front and rear of a 911SC with 225's front/rear. Any input appreciated.
SCWDP911 03-07-2007 06:27 AM
watching
watching...
BK911 03-07-2007 09:49 AM
I just did a DE with 225/50's on 15x7's. The car handled great and didn't self combust.
Porsche virgin 03-07-2007 09:52 AM
You'll find that the guys that drive early cars do this more often.
I have big brakes and a modest budget, so I am going to use 951 7s in the front with 911 7s in the rear for my street tires.
For autox and track, I have a set of 7s and 8s.
SCWDP911 03-07-2007 09:56 AM
Do the 225's fit with no rubbing issues?
KTL 03-07-2007 10:33 AM
I helped a friend (StefanS) do this with his car. He runs 225/50-16 911 7's all around since he has stock brakes. The upside here is that you can rotate tires around the car (without necessarily having to dismount) to spread the wear more evenly. Most everybody knows that the rears wear twice as quick as the fronts. The key is to use the same wheel all around as well as the same size tire so you can rotate everything the easiest. He likes the setup alot and had good results at the track with it.
The key to making the 7's on all 4 corners work best is to use longer 67mm wheel studs and 928 21mm spacers in the rear to get the wider track width. Ootherwise your front track width will be wider than in the rear. Here's a good article on doing this
http://forums.pelicanparts.com/porsche-911-technical-forum/290040-anyone-have-928-21mm-spacers-911-a.html
I have a set of four 951 7's with which I planned to do this as well, since I had 993 brakes (now VCI 964 brakes). Once again, the key here is to use the same wheel on all 4 corners so you can best take advantage of rotating for wear. Using Porsche virgin as an example, if you have front wheels that are different for brake clearance, you won't be able to exchange wheels front-to-rear, since the rear wheels won't fit over the big brakes up front.
225's up front need max. negative camber and rolled or shaved fender lips. I run a BBS 16x8 +28mm offset with 225/50 tires up front and have no problems with my -1 deg. of camber and shaved fender lips. The tire is really close to the shock absorber cover, but that's not a big deal. It can always be removed and replaced with a rubber boot if clearance is tight.
ja78911sc 03-07-2007 11:01 AM
Kevin,
The ability to rotate tires is my goal with this set-up. Thanks for the info!!!
Jim
SCWDP911 03-07-2007 11:12 AM
I'm still confused a little. If you use 16x7 on all 4, is it best to use the 911 offset for the rears and the 951 offsets for the fronts. I may have misunderstood.
ja78911sc 03-07-2007 11:18 AM
951 7's on the front if you have larger brakes. If you have stock brakes 911 7's will work on all four corners.
SCWDP911 03-07-2007 11:26 AM
OK, thanks. Do they look right that way as far as the offsets, or are spacers needed at all. Don't suppose you could post a pic with that setup could you?
BTW, go Huskers! My dad's family settled the Seward and Grand Island areas back in the mid 1800's. While I was growing up, I remember not a Saturday went by without the Nebraska game being on, if it was televised. Wish they could get back to the glory days of Osborne.
ja78911sc 03-07-2007 11:41 AM
v8,
I do not have any photo's. I am considering 911 7's with 225's on all four corners for track use so I can rotate my tires.
Cornhusker Football ;)
SCWDP911 03-07-2007 11:44 AM
My car is going to be a mostly daily driver with hopefully some track use. I just like the idea of being able to dull the rotations and buying 4 of the same tire. Anyone else have pics of this setup?
KTL 03-07-2007 02:50 PM
If you don't use spacers in the rear, regardless of using either a 911 or 951 16x7 (they have the same offset but look different), the car will look goofy. The fronts will stick out more than the rears.
Again, the reason I said you should use 951's all around if you have big brakes is because then you'll have all four wheels that can fit over the front big brakes. If you use regular 911 16x7 for rears, when you try to rotate by mounting them up front they won't fit over 993 calipers.
SCWDP911 03-07-2007 02:55 PM
Point clarified Kevin. I do not know if PO went to bigger brakes or not honestly. I guiess I need to take time to look and figure it out. I see your point though if you do have them (bigger brakes). I have D90 wheels right now. They have spacer on both fronts and rears - not sure how big. What is the best (aesthetically) spacer thickness to use with the 951's?
stormcrow 03-07-2007 04:41 PM
Jim,
I have 7 X 16 on both front and rear of my 78 Targa. Makes the front of the car look fuller and better. No problem with installation - no need to do any mods. In addition, the car handles a lot better.
I will try to post a pic in the next day or so to give you a look see.
"A Porsche does more then just go fast in a straight line"
KTL 03-08-2007 07:44 AM
You'll know if you have big brakes pretty easily. Do the calipers say "PORSCHE" on the faces of them?
It doesn't matter which wheel you use, 911 or 951, as the spacer will work the same with either wheel. The goal of the spacer is of course to push the wheel out further and widen the stance of the car. The biggest slip-on spacer you can get away with safely in the rear is the one I used. I used a 29mm factory 930 spacer and had to use 77mm studs. I found the longer studs to be a tight fit and had to do some tweaking of the parking brake backing plate to get them in there- not happy about that. So i'd suggest you use the 66mm studs and a 21mm spacer.
The 21 mm spacer is a factory Porsche 928 spacer used on the cars up until 1989 I believe? They're not too hard to find. Any 928 being parted out should have them available. There's always someone parting out a 928!
rfn026 03-08-2007 07:50 AM
A friend of mine has a '73S. The car was delivered from the factory with 7x15 Fuchs all the way around.
Richard
Jeff Higgins 03-08-2007 02:22 PM
'72 T with 951 16 x 7's all the way around, wearing 205/55's. Rolled fenders, -1.5 degrees camber front and rear. No spacers on either end. They are tight, but they do fit. 225/50's are the same diameter at about 24.8", and only .8" wider, so they should fit as well. If I can fit them on both ends of my car, they will easily go under the back of an SC, and should fit the front the same as mine.
http://forums.pelicanparts.com/uploa...1173392528.jpg
