Question What is that?
Hi,
I am in the middle of putting a 3.6 into my 930 and I could not find the part in the picture in my 964 manual. So, my question is what in the world is it and how should it be attached???
Thanks,
Sean
Old 03-07-2007, 06:06 AM
durn for'ner
livi's Avatar
Welcome!
I canīt help you on that specifically, but it is interesting you are transforming a turbo into a n/a!
Markus
Resident Fluffer
Carrera '85
Old 03-07-2007, 06:49 AM
Hi Markus,
That is only partly true, the engine started life as a 964 N/A, but Stephen at IA rebuilt and modified to be a turbo engine. I am just in the middle of the install on my car and trying to work out all those little details that make a mod like this "fun".
Sean
Old 03-07-2007, 07:34 AM
Ok, so I have figured out it is the flapper actuator for the variable intake. The question now is how do I control it if I do not have a DME? I am using a megasquirt V3 to run the fuel and spark so do I have to buy a servo that I run with the MS or should I try and use the stock vacuum control and accumulator and have the MS run that? Thoughts?
Thanks,
Sean
Old 03-08-2007, 05:07 AM
