77 911 Carrera door speakers
I am replacing the 30 years old 5" factory speakers in my 77 3.0 Carrera. The replacements out there seem to be either 4" or 6.5. I DON'T want to hack up the door itself. If I have to open the door panel a little, that's no big deal. Nothing looks worse than a pair of speaker that were installed by a hacker. There is a outward ledge right above the speaker opening that sticks out about a quarter inch, so going to a 6.5" is not really a option unless you want to end up with a non stock look. I am sure this problem has been solved before by someone on the board. Any thoughts?
Try a 5.25". Readily available size and ahould fit with not much by way of mods I would think. Try the Infinity Kappa's in that size (Infinity Kappa 52.7 or 53.7 - 2 way or 3 way, respectivley).
Shane - 1984 928S |
noticable difference w/ 6.5 and an amp
6.5 wedge is my bright idea
Ronin LB '77 911s 2.7 PMO E 8.5 SSI Monty MSD JPI w x6 |
Ronin, can you post more info on your bright idea?
Shane - 1984 928S |
i wanted as much wallop from my door speakers as possible. Having a directional tweeter aiming at the other door didn't make much sense to me. That led to angling the bass. All speakers are aimed up & centered at the space between my head and passenger.
After layout i used threaded rivets in the door with long machine screws. Routine sheet metal screws would have been a problem waiting to happen. i also use 75 x 2 amp or the whole thing would have been a waste. Crystal clear ear damage volume is what i wound up with. I don't even use or want rear speakers.
No offense, but that is exactly what I don't want. Looking for a stock as possible appearance.
I installed Pioneer TS-GR1341R speakers in the doors of my 1985. Perfect fit. The Blaupunkt PCxb542 5-1/4" 2-way Speakers from Crutchfield did not fit. The Pioneer were a perfect fit, with the stock grill, with no modification at all.
The Pioneer sound OK. Much better than the 22 year old original speakers. Paul
1985 911 Carrera Moss Green Metallic Steve Wong Chip, WEVO shifter & PSJ, Kuehl Air Conditioning |
Thanks, this is what I want to hear.
