vesnyder's Avatar
Send a message via AIM to vesnyder Send a message via Yahoo to vesnyder
Cabriolet Window Seals?
Does anyone know if you can purchase the vertical window seals by themselves for a Cab? How about once you buy them, how difficult are they to install?
I have an '83 Cab and the passengers side seal is ratty. Evertytime I roll up the window it catches and and gets all bungied up. I have to open the door to roll the window up?
Vance
'83 SC Cabriolet - The "Matrix"
'73 914 - "Spicy Mustard" - SOLD
Old 06-23-2004, 09:32 AM
Did mine a couple of years ago. The rail is held on with nuts on the backside of the pillar. If I remember right it's just a remove and replace after that.
Old 06-23-2004, 09:53 AM
vesnyder's Avatar
What is a source for the part - could not find it on Pelican's site?
Vance
Old 06-23-2004, 10:33 AM
What?
trj911's Avatar
I think I've seen them in a Stoddard's catalog. I think installation for the side seals is just a few screws. I'll check my catalog tonight for a part number.
Tom J.
911SC Cab
SCWDP
CaymanS
Old 06-23-2004, 11:05 AM
Blaine Sellie's Avatar
I am interested in this information also. I understand Vertex has them but they are just rubber, not covered in lame cloth like the originals.
Blaine
1988 Porsche 930 Factory Slantnose
2011 Porsche Panamera Twin Turbo
1974 Porsche 914 2.0 Phoenix Red
1965 Shelby Cobra Replica- 428FE
2007 Mercedes SL55 P30 Package
Old 06-23-2004, 11:21 AM
88'3xBlk911Cab's Avatar
We would be interested in the part number and cost too! Ours are looking a bit ratty.
Blaine - what kind of Cobra replica do you own? We have a Factory 5
Lady 911 driver
1988 triple black 911 cabrio
2005 Saab 9.3 Cab 2.0T
65' Cobra Replica race car
http://norcal-cobras.com
65' Cobra replica under construction
2001 Ford F250 TD 4WD (the Tow Monster)
1993 Chevy Camero LT1
"Life is too short to drive a boring car"
Old 06-23-2004, 11:52 AM
I need these as well. I assume we are talking about the ones along the rear of the window??
85 Triple Black Cab <SOLD>
01 Triple Black Waterpumper
Old 06-23-2004, 12:29 PM
joeclarke's Avatar
Send a message via Yahoo to joeclarke
Window to top seals - Pelican Catalogue
Page 9 under "Weatherstripping & Seals"
Big Bucks!
I'll wait for some noteable event, like maybe my birthday or a lotto win...
the odd Porsche here and there
Old 06-23-2004, 12:48 PM
What?
trj911's Avatar
Try this part. TOP TO DOOR GLASS VERTICLE SEAL.
click here
Middle of page.
Nice work Joe, you beat me to it.
Tom J.
911SC Cab
SCWDP
CaymanS
Old 06-23-2004, 01:01 PM
What happens if you just rip all of the canvas off. My rubber seems good, just the canvas is getting old.
Old 06-23-2004, 03:51 PM
Excellent point. I too thought about this. Is there an adhesive release that would allow to peel of the fabric?
I may try this tonight. I tried to peel it back without a release and the fabric was too brittle.
Blaine
Old 06-23-2004, 04:11 PM
There may be a chemical available to loosen up old/dried adhesive, but you'll probably end up tearing off the old top in shreds anyway. Unless your top is just literally rags though, I'd suggest that you use a digital camera to take pictures (inside and out) at every stage of the removal process. Even the Porsche factory manuals are not real concise on every detail of the installation procedure, so it's best to have something you can look at later on. Get plenty of glue (3M is what I've used in the past)...be patient....make sure the underlying frame is properly lined up (i.e. nothing bent or broken) before you start laying the canvas. I've had the best luck starting in the middle of the top...find the middle point of the canvas, line it up with the middle point of the frame and then work your way toward the back and then finish up working toward the front and the sides.
Marc Morrison
1964 356C coupe
'89 911 coupe
2008 Honda Accord
2008 Ford Ranger
Old 06-23-2004, 06:07 PM
Sonic dB's Avatar
I ripped the old canvas off of mine, and then died the rubber with black dye. It looked much better, though Im due for another dye job.
Old 06-23-2004, 06:33 PM
Sonic,
Did you remove the seals from the car to rip all of the material off or just rip up to the edge?
Did the fabric leave an impression in the rubber or is it smooth?
Blaine
Old 06-23-2004, 07:06 PM
Sonic dB's Avatar
I didnt remove the seals....but I plan to when I have time. For now I just tore away the fabric and dyed around it.
Not an elegant solution but it worked for now. The rubber is smooth underneath and fabric doesnt leave a mark.
Old 06-23-2004, 07:30 PM
SCWDP911's Avatar
sub'd for future ref.
Shane
- 1984 928S
Old 03-07-2007, 05:27 AM
3.2 CAB's Avatar
Hi, when I replaced my cab top fabric and rear section, I also recovered those pillar post seals with some of the same fabric that the top was made from. It was quite a large piece of fabric being it was the cut out for where the rear window was to go, so it was the size of the rear plastic window. Had more than enough to do the job. I took the pillar post seals off of the cab frame, bead blasted them due to some corrosion, then painted them with a satin finish epoxy paint. After that, I preped the seals by removing all of the old fabric, the underlying rubber was in great shape, cleaned off the residue from the old glue, and then applied new adheisive and stretched the frabric to fit perfectly. I used several spring loaded clamps to hold it all in place while the adheisive set. I was very pleased with the results, they looked like new parts, and after adjusting them, they seal without any leaks what so ever. This was a very time consuming job, being I was replacing the entire cab roof fabric, but it all looks like new. I swore to my self that I would NEVER replace another top, due to all of the hand fitting and many, many hours of work involved. I just about drove me nuts because it is a major PITA. I now know why the shops charge so much money to replace them. It has been almost 5 years since I did the job, and it still looks great. There is a lot of hand fitting, cutting, glueing, clamping and adjustments that need to be done to get it correct. I did take many pictures before doing the replacement, so I could have a refference to where all the parts need to go and how they fit. If I had not done the pictures, I really would have been screwed!!! Hope any of this helps. Good luck on the task.
84' Steelslantnose Cab.
1953 Dodge B-4-B-108" 90,127 miles
1953 Dodge B-4-C-116" 58,146 miles
1954 Dodge C-1-B8-108" 241V8 POLY
1973 Roadrunner 440-SIX-PACK*
1986 F-250 Super Cab-460 V8 tow
Newest additions-
Matching numbers 1973 340 Road Runner!!
1948 Dodge B-1-F-152" 1-1/2 ton Dump body, 39,690 miles
others...
Old 03-07-2007, 12:00 PM
I found Automotion (aka Performance Products) to have good diagrams (atleast in catalog) and parts for my '85 Cab. seals.
www.***************/productpage.aspx?pid=101275&name=Cabriolet+Vertical+To+Rear+Of+Side+Window
If you are talking about vertical seal on trailing edge of window, yikes, Expensive !
As other poster, I plan to re-cover when replacing top but my rubber is good.
Old 03-07-2007, 02:41 PM
My canvas is also ratty on my vertial seals a s well as horizontial seals. I see the vertical seals on pelican. Anyone know where to find the horizontial seals?
87 Carrera Cab GP White
01 740i Sport
03 Honda Odyssey
Old 03-07-2007, 05:51 PM
