Hi!
I had another project that I had to finish last night, so I didn't have a chance to bench test anything. I'm pretty confident that my CDI is fine. It still whines (I know, it's only part of the box). Yes, I will clean all connectors. Also, my electrical has been hacked by the PO...installing multiple alarm systems over the years. I've pulled out all that crap and will re-organize all of the wires over the week-end. As far as those connectors, I plan to make a trip to the local pick-a-part and snip off a few of the connectors, once my green wire arrives. If there is a part number on anything, I'll make sure to share, or tell you the type of car I take it from. I've seen that style connector on my old BMW...or was it the Mercedes...anyway, it looks familiar. Thanks again! Brad
'78 911 SC '61 Mercedes 220b '74 Westy 2.0 |
Mahler9th, I've sent you a PM.
Brad
Brad,
Another view of pigtail installed: ![]() Here is a better view of the nolg-nosed connector needed to mate with the pickup coil in the SC distributor ... ignore the 2.7 distributor: ![]() Here is a Bosch Fuel Injection connector that could be installed on a one-piece cable like yours, after the darkened & frayed part is cut off -- to mate with a fabricated or factory pigtail ... less than 1/10 the Eagle day price: http://www.delcity.net/delcity/servlet/catalog?parentid=55011&page=1 The outer shell of above female connector could possibly be trimmed with a Dremel and carbide PC board router bit ... just going out on a limb, brainstorming, here ... to mate with the magnetic pickup coil connector: ![]() Note the long 'snout' part that is required to go into the distributor body: ![]() Revised drawing to show 6-pin CDI connector layout for testing ... looking into the harness connector: ![]()
Warren Hall, Jr. 1973 911S Targa ... 'Annie' 1968 340S Barracuda ... 'Rolling Thunder' Last edited by Early_S_Man; 03-14-2007 at 07:03 PM.. |
Senior Member
I used the factory pigtail. That meant I had to get a Bosch "fuel injector" plug, and a (faston?) connector for the CDI box. If the "faston" connector has the little tab on it, then it neatly replaced the factory connector in the six-pin block, and it stays put.
Man of Carbon Fiber (stronger than steel) Mocha 1978 911SC. "Coco" |
I still can't tell for sure whether the connector that goes into the distributor is an Amp Junior Timer or Amp Junior Power Timer??? The width of the tabs on the pickup coil would seem to imply Amp Junior Power Timer, rated at 25 Amps.
![]() This is the 'standard' female terminal Amp Junior Power Timer connector shell: ![]()
Warren Hall, Jr. 1973 911S Targa ... 'Annie' 1968 340S Barracuda ... 'Rolling Thunder' |
Hi!
Just an update... Well, good news. I found a source for the connectors into the distributor, of all places, in the junk yard!! For $2, I was able to pull a green dizzy wire! The source...old V-8 Mercedes S class. From the '70's! Yup, they share the same connector! They have a funky round coax like connector at the CDI end, and a nice bosch connector at the other. I was also able to pick up some AMP ends out of BMW 325's. I also took some other similar looking ones from VW's. I'll use the one that works the best. So, I just cruise around the yard looking for these car types, and if I find something that does not look dry rotten or burned up, I take a look. The Dizzy connector that I found is still white, not yellow, in color! The wire was covered in thick grime, so it seems that it was protected. I also decided to buy a MSD 6AL. I got it for $230 (new), so I can't complain. So, what I'll do is play with my new collection of parts and see what happens. When my new pig tail comes in, I'll use it and connect it up to the MSD. Anyway, if you are looking for green wire spares, I suggest that you pack your 13-15mm socket with extension, a screwdriver and go parts hunting. I have 3 wires now!! More than enough. I would still like to find an original source for the bosch part, and in the mean time, I'll just keep cruising the yards. Thanks again, and I'll keep you up to date on how it all turns out... One quicky, can I use a stock coil with the MSD? Thanks! Brad
Brad,
I recommend the MSD High-Vibration coil #8222. Here is a cheaper source for the 2-position Bosch/Amp connector and pins [have to be ordered separately] that needs to be added to any cable mating with the pigtail out of the distributor: http://www.kayjayco.com/catPConnectors.htm ![]() ![]()
Warren Hall, Jr. 1973 911S Targa ... 'Annie' 1968 340S Barracuda ... 'Rolling Thunder' Last edited by Early_S_Man; 03-11-2007 at 07:06 PM.. |
Re: The Green wire...
How did my bearing-tool go? The tool chest drawer misses its tenant. Plus, I dont want to spend your deposit. ![]() ![]() |
Hi!
I sent you (cab83_750) a PM! Brad
Somatic Negative Optimist
Warren:
Quote: "I still can't tell for sure whether the connector that goes into the distributor is an Amp Junior Timer or Amp Junior Power Timer??? The width of the tabs on the pickup coil would seem to imply Amp Junior Power Timer, rated at 25 Amps." According to the specs in German, the dimensions are the same but the rating is different. Contact-material and contact-area are different for the 25A but the outside dimensions for the plug are the same as the 20A.
1980 Carrerarized SC with SS 3.2, LSD & Extras. SOLD! 1995 seafoam-green 993 C2, LSD, Sport seats. ![]() Abstract Darwin Ipso Facto: "Life is evolutionary random and has no meaning as evidenced by 7 Billion paranoid talking monkeys with super-inflated egos and matching vanity worshipping illusionary Gods and Saviors ". ![]() |
Anyone know which terminal is for the center wire and what terminal is for the wire that wraps around it?
As you can see by the photo, the notch on the one side of the connector is facing the camera ![]()
John A. 1979 Porsche 930: 3.4L, SC cams, Twin plug, Leask WUR, Custom SSI turbo exhaust, Tial WG, K27HFS, and we can't forget the Zork (short lived depending on my homeowners assoc.) 05 Boxster S: For the Track. 06 Dodge Ram 2500 Power Wagon: Tow Vehicle |
Use an Ohm meter, or voltmeter (set to Ohms) to test continuity between the old connector, it's plug/wire and compare it to the new.
So, if the plug that goes into the dizzy has 2 slots side by side, put one probe in the right side of the connector and figure out if it's the center wire or the one the wraps around. Once you figure this out, you should be able to repeat the procedure on the new plug to determine which is the right way around. Does this make sense? If not, the worst case is that your timing will be way off and it will probably backfire and run like crap if you've got them reversed. Brad
The issue is, my old wire didnt have the connector on it. It was wired strait to the 6 pin. I dont have an ohm meter but could pick one up. I am just not sure which wire is which without having to cut the new wire at the connector
Born to Lose, Live to Win
Does anyone know what these parts are called? i went to the Kayjayco webpage to order them, however....the site has photos showing them but they are not labeled...and they have many different product selections but im afraid im going to order the wrong parts...thanks.
1983 911sc 2025 Chevy Colorado ZR2 |
Go to a junkyard with your side-cutters..
These connectors are used on other cars; I found many on different VW models.
SEVENT9
Full end-to-end green wire supplier found!!!
FULL END-TO-END GREEN WIRE SUPPLIER FOUND!!!
Reviving a very old thread here to share some info I have discovered about the infamous Green Wire. As we know, the one provided by our host and most their suppliers is too short and need to be spliced in to the original cable and removing/bypassing the older, cooked section. I hunted everywhere for a solution and ended up reaching out to the guys at Kroon Wire who make pretty much every kind of wire/engine harness you can imagine for all our cars. The can provide the CDI harness as a full replacement which includes the original Bosch Distributer Wire: It is expensive but very well made and a great replaceent preserving the original wiring specs of our cars. However, after emailing them they are very aware of this issue and while it is not advertised on their site that explained the following"
So thought I should share this here because it looks like a great option for anyone who needs to replace their Green Wire (perhaps me in a few days... we shall see)
- - - - SEVENT9 '79 SC Black: My first 911 & my birth year!! ![]() http://forums.pelicanparts.com/porsche-911-technical-forum/1000359-79-outlaw-build-thread.html |
I disagree on the Bosch CDI I have done lots of experimenting and testing on my 2.7 MFI motor. My car runs MUCH better on a good aftermarket CDI and I have lots of other benefits like soft rev limiting instead of that stupid centrigugal rotor, and data gathering. The Bosch CDI is a 50 year old electronic deisgn......think about that. Most of the components belong in a museum. If it has been in use for 40 years, gee that is not a risk I want to take when I take a drive. My Bosch CDI is in a nice little box in a cabinet in my shop. I am not a big MSD fan, but there are many good choices available. I have had my car for 20 years and the best thing I ever did was to replace the Bosch CEI and take out the points. I could finally have a strong running reliable engine. I chose a Daytona-Sensors CDI and swear buy it. Soft rev limiter, data gathering, programmable, and it has been dead reliable for 15 years. Put you Bosch CDI on the shelf.
RGruppe #79 '73 Carrera RS spec 2.7 MFI 00 Saab 95 Aero wagon stick 01 Saab 95 Aero wagon auto 03 Boxster 90 Chevy PU Prerunner....1990 |
NOT ME!!
URO Ignition Distributor Wire 930 602 907 01 is for 1978-1989 911 and 1978-1979 930, and is approximately 128mm long. We've recently modified this wire slightly with updated connectors, which grab the pins more securely than our first production run.
Wire 928 602 907 00 is technically for the 1978-1984 928, but has the same connectors and is 725mm long. Which means it can be used in place of 930 602 907 01, if additional length is needed. ![]() Edit: We aren't discontinuing 930 602 907 01 after all, and will continue to offer both lengths.
URO Parts Online Catalog for Porsche: https://apaindustries.com/catalog?make=2 Last edited by UROParts; 01-24-2020 at 02:11 PM.. |
ROW '78 911 Targa
Looped and zip tied?? Sounds appealing... and should look great! (NOT)
Why drop the only low priced alternative to the current $75 and up Bosch or Porsche supplied units? A 3 foot wire with only the distributor end installed would be better for restoring an original style SC harness. The turbo and some row cars all came with the replaceable short wire, and most that have fixed their bad wire have gone to the short wire. So those customers won’t go for the loopy look....
