-   -   where to find bellows deletes? (http://forums.pelicanparts.com/porsche-911-technical-forum/334564-where-find-bellows-deletes.html)
m110 01-11-2015 06:50 PM
rubber
I got sick of waiting and just replaced the whole bumper
http://forums.pelicanparts.com/uploa...1421031014.jpg
I have a nice photo of the part we are looking for...will post it
m110 01-11-2015 06:52 PM
from this thread:
http://forums.pelicanparts.com/porsche-911-technical-forum/409560-panels-replace-bumper-bellows-3.html
http://forums.pelicanparts.com/uploa...1421031173.jpg
3literpwr 01-11-2015 07:06 PM
There is hardly a straight line on a 911. By removing the bumper strip, it seems to really make that big flat surface of the bumper stand out. I actually wanted a IROC bumper when I got my SC and not can't stand them on a narrow car. I guess i'm just being a picky designer.
sc_rufctr 01-11-2015 07:14 PM
Originally Posted by efhughes3 (Post 2781791)
I've been looking at the whole scoop situation. Obviously, there is the piece made by jmpro sold by Pelican that replaces the marker light. It would seem this one is a pain to install-getting to the nuts holding the lights may be a bit difficult.
I started looking at the bellows, and noticed that it would allow airflow to the front of the cooler, if a scoop was there. So, I started playing around with some aluminium, and this is what has come about so far. I've got a DE this weekend, and I'm thinking about giving this piece a try, although we're forecast for cooler weather, only about 90 degrees. I should be able to see if it does any good, even with the cooler temps.
What do you all think? I'm about 1 1/2" clear at the narrowest points, and 6" high, so I figure about 9-11" sq inches of frontal surface as it is, but that could be increased if I make another. I'll drill two holes at the rear, and bolt thru the bellows mount holes, using a rubber gasket to protect the paint. The front will be a little tougher to get to the inside for the fastners, but I'm thinking longer bolts with standoffs. Hammertone paint will be used to hide the hammer marks at the rear.
http://forums.pelicanparts.com/uploa...1156887932.jpg
http://forums.pelicanparts.com/uploa...1156887962.jpg
http://forums.pelicanparts.com/uploa...1156887985.jpg
http://forums.pelicanparts.com/uploa...1156888008.jpg
http://forums.pelicanparts.com/uploa...1156888030.jpg
http://forums.pelicanparts.com/uploa...1156888054.jpg
http://forums.pelicanparts.com/uploa...1156888093.jpg
From this thread... http://forums.pelicanparts.com/porsche-911-technical-forum/301330-oil-cooler-scoop-replace-bellows-rough-model.html#post2781791
RSBob 01-11-2015 08:35 PM
Originally Posted by m110 (Post 8435554)
Like this image I thought it would be cool to creat a shell similar to this which slips over the existing bumper which could be bonded to it, thus keeping the impact protection. Sure the shell would be toast in a hit, but the rest might be protected. If made wide enough on top with a slight rise, might be able to ditch the rubber smile at the hood as well as the bellows.
will hung 01-12-2015 11:49 AM
This looks awesome. Is there a build thread for the car? More pics?
911finally 10-26-2023 07:48 AM
bringing another 2007 thread with most recent comment from 2015 back to life, gotta love this place
anyone seen any newer bellow delete options?
Aztim 01-11-2025 09:24 PM
any updates?
