Stahlwerks.com
jhelgesen's Avatar
Send a message via Yahoo to jhelgesen
3.0 carb install
Started installing my new set of webers in the 912-6 today.
First, yank out the CIS (Euro fuel dist, big port version, whats it worth?)
Then I had an empty engine bay....
Now I have the carbs trial fitted.
I need to find a few bits and pieces, one of the throttle linkages is little worn, and I need fresh fuel line and filters. I may change all the fittings over to AN's to match up with the rest of the lines in the fuel system. I'll be using my high pressure fuel pump, so I need to figure out the fuel circuit.
Another question I have, is what do I do with all the left over wires from the CIS harness?
John Helgesen
Stahlwerks.com restoration and cage design
"Honest men know that revenge does not taste sweet"
Old 03-10-2007, 03:08 PM
rfuerst911sc's Avatar
Whay I did with the left over wires was to tie them up with zip ties as cleanly as I could to the harness that they branched off of.
Old 03-10-2007, 04:33 PM
Slippery Slope Victim
NY65912's Avatar
Nice work,
make sure you get a top quality fuel pressure regulator, nou a cheap one with the dial. I believe Mallory units are what is supplied by PMO.
Also, very important..........a really good fuel fliter, I'm running a Racor that has a water seperator as well.
Cheers
MikeČ
1985 M491
Old 03-10-2007, 04:38 PM
Stahlwerks.com
jhelgesen's Avatar
Pressure gauge and plumbing supplied with the carbs.....don't know if I'd trust it with a CIS fuel pump.
Strongly considering the circulating system and all AN lines, either use PMO bars or XRP banjo fittings (if I can find them online somewhere)
Does anyone have experience with the PMO or XRP fittings?
Thanks!
John Helgesen
Old 03-12-2007, 05:01 AM
NY65912's Avatar
CIS fuel pump is OK. As long as you have a GOOD press regulator.
Highly recommend the AN fittings. PMO has the parts as well.
If you need pics I'll snap a few of my install.
Good Luck
MikeČ
1985 M491
Old 03-12-2007, 05:39 AM
Stahlwerks.com
jhelgesen's Avatar
Thanks Mike, any and all pictures are welcome!
John Helgesen
Old 03-12-2007, 05:44 AM
19 years and 17k posts...
azasadny's Avatar
John,
I just put 3300 miles on my '74 911 with Webers and it ran great! You'll love the sound and performance of the carbs! Good work!
Art Zasadny
Learning the bass guitar
www.ford.com
Old 03-12-2007, 06:31 AM
Stahlwerks.com
jhelgesen's Avatar
ooops, forgot the picture of the gauge in earlier post....
John Helgesen
Old 03-12-2007, 06:40 AM
