ajmarton's Avatar
What caused this to break and have I damaged anyting else ....89 911 cab...
I was checking the speedo sensor under the 911 on the trans (which is now working) and unfortunately stumbled across this problem at the rear pasenger side of the 911 .... (view from passenger side wheel well). The piece that the bar attaches to just seared right off. At first, I thought I was just missing a nut but then realized it was still attached to the sheet metal. I am taking it to the shop tomorrow as I am worried about driving around with a broken sway bar (?) mount. Any ideas on how this happened and whether I have screwed up my suspension?
Old 03-11-2007, 04:44 PM
Pretty common on these cars,....
Your shop can weld that up but for a more permanent repair, I would remove the factory mounts and have them weld on the WEVO ones.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
porsche@rennsportsystems.com
www.rennsportsystems.com
Old 03-11-2007, 04:50 PM
ajmarton's Avatar
Is there a part number to it? Or will they know what I am talking about when I call?
Old 03-11-2007, 04:53 PM
syncroid's Avatar
911 501 983 00 GRV is the part number.
Dan
2002 996 C4 Cab w/ Jake Raby 4.0
2024 Tacoma TRD Offroad 4x4
2003 Range Rover HSE
Old 03-11-2007, 05:00 PM
Friend of Warren
It is the rear sway bar mount and yes as Steve said it is pretty common to tear out. Replace with the heavy duty mount.
Kurt V
Old 03-11-2007, 06:08 PM
3.4 Bigger is better
88-diamondblue's Avatar
Do it once. WEVO mounts.
Michael
88 911 Diamond Blue CE Carrera 3.4 HC3.4 member
2020 Honda Passport
Old 03-11-2007, 08:40 PM
ToddM's Avatar
Send a message via AIM to ToddM Send a message via Yahoo to ToddM
I agree dont F around use the Wevo mont. They have to grind thie old mount off and I think you'd only like to pay for this service once, eh?
The replacement factory part also breaks...
-Todd
'82 911 SC Coupe w/'92 3.6L, bulletproofed 915/62 w/GT LSD & Wevo goodness, Rennsport RSR/Bilstein Sport, SRP ARB, ER Polybronze, BK strut brace, 15x7/8" Fuchs.
Sold: 92 964 Turbo, 81 SC, 96 993 Coupe, 82 SC, 89 Carrera Cabriolete
Old 03-11-2007, 08:43 PM
ajmarton's Avatar
Thanks for the quick responses. I am going to order the WEVO mount tomorrow and then confirm that my shop is familiar with the repair.
Old 03-11-2007, 09:04 PM
