Non 911 Tech ?
I have an old motorcycle I'm working on and the fuel tank has very light surface rust inside. Does that require a complete lining of the tank or is there something I can clean the inside of the tank with?
I appreciate your input. I know it's not 911 related but I also know there are alot of smart folks on here so I thought I'd ask here first. Thanks again
1983 SC - sold
2002 996 C4S - sold
1968 912
Old 03-05-2011, 12:55 PM
76 911S Targa
Had the same problem with my Norton. Go to the auto parts store and get a gallon jug of "mag wheel cleaner". It contains, if you read the label, a mixture of phosphoric and sulfuric acids, diluted, along with a powerful detergent. Remove tank from bike. Remove all gasoline. Rinse the tank once with alcohol to remove residual gasoline, then rinse with water to remove the alcohol residue. Plug the fuel line outlets. (I just turned mine closed) Pour a quart or more into the tank, close the lid and slosh it around. If you only have a light film of rust the solution will remove it in ten minutes or so of sloshing. If it has big chunks, add some old bolts, nuts and washers and slide them along the entire inner surface of the tank with the solution. This breaks loose the larger deposits adhering to the inside of the tank and lets the solution get down to bare metal. It also cleans up the nuts and bolts. The phosphoric acid leaves a nice gray coating on the steel which helps protect it from oxidation. Dump out the solution with freshly clean hardware into a bucket, inspect, repeat if needed. Rinse with water, then with alcohol to remove the water and air dry. If you have any leaks they will be apparent and can be repaired, otherwise you just use the newly cleaned tank.
Old 03-05-2011, 01:14 PM
Targalid,
THANKS! That sound like it'll work perfect. AND, I just happen to have a few nuts and bolts that need cleaning
1983 SC - sold
2002 996 C4S - sold
1968 912
Old 03-05-2011, 02:50 PM
Worked like a charm! Thanks again!
1983 SC - sold
2002 996 C4S - sold
1968 912
Old 03-06-2011, 01:09 PM
76 911S Targa
Ride to live! Live to Ride!
Old 03-06-2011, 01:30 PM
