e p slick's Avatar
Alternative marque cold start valve?
Anyone ever determine an alternative marque (and more affordable) cold start valve for use with early 930? Can't be that difficult to figure out if you have the time. Seems as if some of the inexpensive Mercedes cold start valves - or other thread- compatible designs would have similar thermal properties as the more expensive (because it says Porsche) valves. Any thoughts? Thanks EPS
AMG V8 SL55 Mercedes, 993 C2, 86' Carrera 3.6 hot rod, Purple 1998 993 that didn't make the cut, 3 very old 930s, A/Fuel Dragster CH3NO2 (R.I.P.), Blown Alcohol TAD, AA/AA, 360 Maxim wingless, Cummins Turbo Diesel. Amateur Welder, Painter and sculptor sort of. -
Old 03-14-2007, 12:45 PM
