one of gods prototypes
bell's Avatar
remove powdercoating?
my fan is powdercoated white, and i'm in need of a change as the white gets too dirty too fast.
what is the best way to remove the powdercoat? media blast? don't want to damage the fan
thanks
Brought to you by Carl's Jr.
Old 03-13-2007, 05:37 PM
3.4 Bigger is better
88-diamondblue's Avatar
Aircraft stripper works well. While pc'ing my fan had problems with out gassing and had to redo the fan. Stripped it twice with stripper then bead blasted and finally got it done to my liking. Also tried sandblasting but would have taken way too many hours to do.
Michael
88 911 Diamond Blue CE Carrera 3.4 HC3.4 member
2020 Honda Passport
Old 03-13-2007, 06:13 PM
Buy new fan and replace...really. Tried to do it on some suspension parts on my old 944; it was an exercise in futility. You can get a new fan used much easier and just power coat the new one (+ you can sell your old fan)
Old 03-13-2007, 06:16 PM
DinFtown's Avatar
Send a message via AIM to DinFtown Send a message via Yahoo to DinFtown
Regular powder is baked on at 400deg... to remove bake it for 20-30 mins at 700 deg... that will cook the powder off, like stripper.
David Walsh
77 911
04 ram
2 E30's 87'
and my John Deere
Http://www.ProBraking.com
Old 03-13-2007, 07:55 PM
I'd only do that if money is of no concern... I'd rather spend my $ on something else. I haven't priced a new fan, but I doubt they are cheap
edited: ps: I just did a quick price check... 676.50 for a new fan (or remove the powder coating) ...seems obvious to me.
Old 03-14-2007, 02:58 AM
I ment a "new to you" fan. I'm sure someone here has one for not a lot of $$
Old 03-14-2007, 04:09 AM
I sold a used one (powder coated) for a couple hundred some time back...they aren't free and "good ones" are becoming harder to source.
ps: Where y'at in Jax...I used to live on the Southside/Baymeadows many years ago...
Old 03-14-2007, 04:18 AM
Baking it is probably your best option at removing the powdercoating. Make sure to get it balanced afterwards.
Old 03-14-2007, 07:38 AM
the the is offline
If you are getting it re-powdercoated, don't do anything. Just drop it off at your pcoater. They will remove it by putting it in the oven overnight.
Old 03-14-2007, 07:48 AM
Use aircraft stripper.Have done it many times over.
Dan
Old 03-14-2007, 01:30 PM
Wangrande's Avatar
Dan is correct.
Aircraft stripper turns it to a stretchy rubber-like peel-off substance. Fast & easy.
72 T 3.2
Old 03-14-2007, 07:30 PM
Bland
unclebilly's Avatar
I have sandblasted powder coating off of gasket surfaces before - these were supposed to have been masked at the coater...
It was no big deal. Another option is to soak in something nasty. I bet gun wash would work if you soaked it for long enough.
Old 03-14-2007, 07:49 PM
Super Moderator
cstreit's Avatar
www.eastwoodco.com
They make a stripper specifically for powdercoating. Aircraft stripper is "okay" but this stuff is the schiznit.
Chris
1996 993 RS Replica
2023 KTM 890 Adventure R
1971 Norton 750 Commando
Alcon Brake Kits
Old 03-14-2007, 08:04 PM
bell's Avatar
good info, i'm going to check with christian (a quiet boom) as he has industrial ovens at his shop, if we can't go that high in temp i'll try the stripper from eastwood......will a qt. be enough?
Old 03-14-2007, 08:29 PM
I did my fan housing twice plus front and rear sway bars with a quart. Once you get the stripper washed off, a pressure washer helped get the pc out of hard to reach places. Wear safety glasses and rubber gloves. Aircraft stripper will eat through nitrile gloves in a very short time
Michael
2020 Honda Passport
Old 03-14-2007, 08:42 PM
