Boge and Bilstein Experts -- input pls.
I just received my revalved Bilstein shocks and struts today! :D :D
Although I made notes of the parts when disassembly, could you please confirm that: 1. I insert the Bilstein strut into the Boge housing. The collar gets tightened at 140 nM, correct? 2. I protect the strut with the 'green tube cover.' There will NOT be any rubber washers between the strut tower and the 'green tube cover.' Correct? 3. Once I insert the green-tube, there will NOT be any rubber washers between the green-tube cover and the fender/strut-mounting-hole. Correct? BTW, I used to be able to compress those struts prior to the revalve job. Now, I need to be the Governator to compress them.!!! :eek: :eek: :eek: Thanks. |
| All times are GMT -8. The time now is 11:41 AM. |
