lespaul's Avatar
StoneGuard in Aeresol Can or BrushOn?
I have removed most of the undercoating under my wheel wells using a heat gun and scraper. Not a bad job, but some really really sticky white stuff is impossible to remove. I plan to POR-15 all exposed metal with a couple of coats.
Now, I am interested in putting stoneguard over the POR-15. While a dimpled original look would be nice, I don't really want to buy an aircompressor and spray gun - and do all the clean up of the spray gun. I just want to protect my car from chips and rust.
It seems that my options are:
1. More POR -15 layers, and skip the stoneguard all together.
2. Brush on Wurth SKS Stoneguard over the POR-15.
3. Use an aeresol can of some quality Stoneguard over the POR-15.
Any opinions on this? Is there such a thing as option 3?
Brad
Inventor of SNAPGAP - The Valve Adjustment Solution
Patented in U.S. and Europe. Go to SNAPGAP.US or PM me.
https://www.pelicanparts.com/More_Info/SNPVAK11146.htm?pn=SNP-VAK11146
Old 03-15-2007, 08:37 AM
Friend of Warren
They make a spray on truck bed liner. Sold at auto parts stores. May be just what you are looking for.
Kurt V
Old 03-15-2007, 09:20 AM
lespaul's Avatar
Great suggestion Kurt. Thanks.
Brad
Old 03-15-2007, 09:27 AM
Stressed Member
Scott Clarke's Avatar
I'd go for the Wurth aerosol cans. This would give you the correct finish, and could be removed in the future if the car needed further restoration.
-Scott
'70 911E short stroke 2.5 MFI. Sold
'56 Cliff May Prefab
Old 03-16-2007, 07:51 AM
rfuerst911sc's Avatar
I am restoring a 914 and I recently used the spray can of truck bedliner in the rear trunk. This stuff is relatively cheap ( $7.00 can ) and covers well and leaves a nice uniform finish and appears to be tough. I may use this on all the wheelwells also.
Old 03-16-2007, 09:54 AM
lespaul's Avatar
Thanks for the suggestions. I looked at the various products on the Net. The truck bedliner stuff looks hard as nails -- but, for what it is "Wurth" I decided to go OEM and bought 5 cans of Wurth Spray Can Stoneguard for $75. This should do my whole car, and I don't have to do any clean up of a spray gun or buy an air compressor. Just throw the can away when I am done. If anyone else is interested, you can get it here . . .
http://classic-motoring.stores.yahoo.net/wurstonguarb.html
Brad
Old 03-16-2007, 12:39 PM
Check out this site - he has some interesting ways of getting that factory style underbody finish that I'm going to try myself...seems to work well on his project.
http://members.aol.com/darryld/912.htm
77 911S
68 Dnepr MB750
80 Dnepr MT10
Old 03-16-2007, 01:24 PM
lespaul's Avatar
Thanks for showing me this guy's site. It is an inspiration.
Brad
Old 03-16-2007, 01:40 PM
NP. There are lots of good tips over on the 912 BBS
http://www.912bbs.org
Curt
77 911S
68 Dnepr MB750
80 Dnepr MT10
Old 03-16-2007, 05:54 PM
