H4's on early car
Need to replace the front lamps on my car. While I can source the orig sealed beams, I'm considering the option of upgrading to halogen. Anyone have any experience with this on an early car? I know the 67 fuse box is not a marvel of modern engineering- I'm not sure it could handle the extra power draw.
Thanks Last edited by dogslovetrucks; 03-16-2007 at 09:42 AM.. |
Not sure what you mean here 7" halogen sealed beams are available just about anywhere or are you trying to update to th RoW H1 or H4 like these ![]() safer wiring w/ a relay is desirable even w/o any increase of current draw for the lights, and is easy enough to do there are quite a few threads on this topic in the archives
Re: H4's on early car
Many of us (including me) have upgraded. The upgrade consists of a set of relays (one for high beams, one for low beams). The existing circuit is used to energize the relay and close a set of contacts. The set of contacts connects a new fused circuit from the battery to the headlamps you want to operate. There are two popular suppliers of the upgrade kits: Marcus Sucro (http://members.rennlist.com/msucro1/relaykit.htm) and Daniel Stern Lighting (www.danielsternlighting.com). Marcus's kit is less expensive but is designed for cars later than yours and mine and you will need to do some customization. Daniel's kit has most of the parts that you need but you will need to figure out the wiring yourself. I will say that Daniel does include some very nice Hella headlamp sockets in his kit and they should be used by all. Below is a suggested wiring (you only need to consider the hi and low beam parts unless you also want to add driving and fog lamps).
Thanks for the links Harry
Monkey+Football
Who's car is this?
<Insert witty comment> 85 Targa Wong Chip Fabspeed M&K Bilsteins and a bunch of other stuff. |
These are the 7" H4 replacements from out host. I'm using standard wattage bulbs, but haven't installed relays (yet). But it's been a few years with no problems, and the increase in visibility at night, even without the relays, is substantial.
Roger 1968 sand beige 911 Normale coupe #11830091 1984 metallic moss green with champagne interior 911 Carrera coupe 2012 silver with red interior Boxster |
I had standard wattage bulbs and my stalk got fried at about 120k miles. The relays will not change the light output very much, but they will save you from a a possible failure when you do not need it and a need to buy a $179+ part to repair the damage.
I'll have to look into mine, they were done by a PO and I don't think they used headlamp relays. There seems to some sort of power drop when you let off the gas. Just ever so slight, but the lights do dim. Visability is great though.
Rick
Rick Phillips 1972 T Targa MFI |
I'm doing the '84 this summer (I'm really not driving the '68 after dark much anymore). But I'm contemplating making The Redman at Road America with the '68. Since it would be with significant night driving, I'd kit that car as well before I take it.
