-   -   Dropping the steering rack... (http://forums.pelicanparts.com/porsche-911-technical-forum/336101-dropping-steering-rack.html)
RoninLB 10-20-2007 06:30 PM
Originally Posted by toddu (Post 3216337)
Can I re-pack it while it's in the car? Should just be that access cover on the bottom that I can easily get to.
wish i knew what's available to do once that cover is off? http://forums.pelicanparts.com/support/smileys/dom.gif
Jeff Hail 10-20-2007 10:00 PM
Make sure when you reassemble everything the rubber shaft bushing (with the needle bearings) at the firewall didn't fall down. I have seen one very worn one disappear to be found later when the shaft clunks on the underside of the cowl after reinstall. It's rare but sheet happens.
