distributor wiring
1977 911s dist. cap has a coil wire going to what appears as another coil mounted on driver's side in engine compartment.
the coil wire that is mounted on fan shroud goes no where. any insight on this? does not seem to affect anything not plugged into dist. cap. thanks tommy |
Tommy,
Welcome to the Forum. You will find a lot of help here. What CDI do you have? What wires go to the functioning coil? Is there anything hooked to your original ignition transformer? Like they say; “A picture is worth a thousand words.” ”How to post images (pictures) on Pelican“ Best, Grady
ANSWER PRICE LIST (as seen in someone's shop) Answers - - - - - - - - - - - - - - - - $0.75 Answers (requiring thought) - - - - $1.25 Answers (correct) - - - - - - - - - - $12.50 Last edited by Grady Clay; 03-19-2007 at 06:58 PM.. |
