Guest
Posts: n/a
what is good 911 compression
just had compression checked on my '88 Carrera:
1=165,2=170,3=170,4=170,5=170,6=160 Is this good? Should I be worried about one cylinder being 10 lbs lower than 4 others? |
Guest
Posts: n/a
If you are counting correctly, the #1 and #6 cylinders are catty-corner to one another. I have always wondered why these particular cylinders show a lower reading?
The figures seem good to me, but I'm no expert. Certainly the figures may be higher due to the additional carbon buildup in the cylinders themselves. I have just finished running Techron 20oz bottles through two consecutive tankfuls, putting the car through its paces for a minimum of two hour runs (heat+Techron=carbon breakdown). The car is now on jackstands and I will perform a valve job along with rotor swaps and other bits and pieces. I will again have a compression test and a leakdown, this time noting where the hiss is coming from on the car. jw |
Guest
Posts: n/a
John,
The general guidelines are that no cylinders be more than 10% from the mean, and with a mean of 167.5 psi, you are well within those guidelines! So, no, you don't have anything to worry about at all! ------------------ Warren Hall 1973 911S Targa |
Guest
Posts: n/a
The reply that Warren gave made me think of another question. If all cylinders were between 115 and 120, as in the case of my '77 930, can I assume that my numbers are Ok for my engine.
Guest
Posts: n/a
Beagle,
Those don't sound bad at all for a 6.5:1 compression engine, and that is what the 3.0 turbos had, right? ------------------ Warren Hall 1973 911S Targa |
Guest
Posts: n/a
I just tested my 1988 Targa. Here are the results:
1 = 155 2 = 150 3 = 150 4 = 145 5 = 160 6 = 155 AVG = 152.5 I think that this is with spec. I checked #4 twice with the same results. Am I right? ------------------ E. William Reinecke 1988 Carrera Targa |
