fancytown
Should I switch to these headlights?
A co-worker of mine said he had some 911 headlights in the garage he wanted to give me. So, sure, free headlights. Anyhow, my car has H4's. The outside of these boxes said H1 on them. There are 3. Two are the same, and then there's a stray. Is it worth while cleaning these up, and installing them? If so, do they fit on a SC?
My car: The two same ones. Lenses say E1 on them: ![]() And the stray one...
all cars sold. |
RETIRED
H4s are the top of the line in MY book....sell them.
BTW.....If I can find a 6V bulb for them....they would look real trick on the 356 Outlaw I'm doing right now. Keep me in mind please.
1983/3.6, backdate to long hood 2012 ML350 3.0 Turbo Diesel Last edited by Joe Bob; 03-21-2007 at 08:21 PM.. |
+1. The H1's are worth more $$ than the H4's, sell them and invest the money in a relay/wiring upgrade and higher wattage bulbs if you haven't already done any of that.
Michael Sans Porsche...for now 2009 Mazdaspeed 3 Grand Touring daily driver / DS autocross toy 2010 Subaru Forester X Limited - wife's daily driver |
You can sell the H4s to me...
1978 911 SC coupe (whenever-I-get-to-the-lake driver) 2008 VW R32 #2846/5000 Past Rides: 1999 Jeep Cherokee Sport-lifted |
fancytown
Yeah, I figured the H1's might be "desirable" to a lot of people. I can't just sell them, as they were given to me with the thought I'd use them. I might, but it seems like "work" to hook 'em up. Being in the middle of a top-end, "work" is not attractive to me. We'll see.
So they should just bolt right up?
all cars sold. |
Jay, I don't think there's any difference in the wiring between H1's and H4's as it relates to the car's wiring for the headlamps, so they should mount right up.
the H1's are "desirable" to a lot of people b/c they have 2 sep. bulbs that can be moved independently. that's what those look like to me but I'm not sure about the lens on them.
check to be sure it's the right lens and see if the elec. plug matches w/ your car
"A man with his priorities so far out of whack doesn't deserve such a fine automobile." - Ferris Bueller's Day Off |
Anyone know how to clean these lenses (inside and out)??
thx,
Luis "once was - Wickd89" Carrera 3.2 - "Faster, Stronger, Better" -- 2008 Toyota Camry SE V6 (mine) -- 2005 Toyota Sienna (hers) -- 1989 911 Carrera Cabriolet -SOLD |
Ayo Irpin, Ukraine!
Jay, the lenses are correct on your H1s (red rings). Although that one looks like it's been used for a fishbowl. I prefer the H1s. You get more light out of a H1 versus H3 of the same rating. Not sure about the H1 versus H4. In my opinion the long range beam is more focused and you have more control with the placement. The H4 is a compromise between High and Low beam. Even though your circuitry can handle the H1's (used on the 911S since 68) I agree with recommendations to isolate your switch with the use of relays to handle the high current circuit.
Harmlessly passing gas in the grassland away; Only dimly aware of a certain smell in the air |
or completely disasemble and clean/replate it like the fine German watch that it is
thanks Randy. Sounds like CLR would work as well. Coooool.
CLR?
You gotta use/keep the H1's. Free? that's crazy.
You see 'em in the classifieds for upwards of $800/pr. Put on the H1's. Sell your H4's The stray one looks like a H5--not worth much.
Mike '86 911 coupe '85 BMW 535i '11 Cayenne |
C Calcium L Lime R Rust Some nastyish cleaner for soap scum and hard water deposits in the bathroom etc. Should work pretty well...I might be a little worried about the chromed reflector surface inside the light though.
Cool freebie! Cooper
Cooper's Classy Car Care Providing Clear Bra installation, Paint touch-up, Detailing PCA/OCR since 1997 '81 911SC, '95 993 Tip. Project 'Euro spec' '70 914-4 w/2.0 & side shifter |
oh that stuff - isn't it a pretty strong acid?
you might want to try it on the chrome on your neighbor's Buick before you put it in the headlight
fancytown
Thanks for the replies. I guess I'll refinish these and use 'em on my car. I live in the city, so I never really noticed, or needed to worry about headlight intensity. But, I don't like the H4's I have with the trim ring cover setup the PO put on.
all cars sold. |
I guess it would be safer to start out with soap and water. Love my car, but the headlights look milky.......
Bye, Bye.
![]() Too many other people would just sell them.
Elvis has left the building. |
Ayo Irpin, Ukraine!
If you have a lot of dirt inside the housing (like Jay's) you need to take the lense and the trim ring off. If you try to clean by the slosh method you'll end up sand blasting the plating with all the material in there. Also, don't clean the plating by hand. The aluminum coating is extremely thin (not chromed) and you'll take it off. It's best to use the slosh method on the reflector/housing seperately inside a big heavy duty plastic bag with Isopropyl alcohol and let it air dry. The lense you can clean normally like any other glass. I use a mild detergent with a soft toothbrush to get in the flutes and then finish with a lint free cloth.
Harmlessly passing gas in the grassland away; Only dimly aware of a certain smell in the air Last edited by 70SATMan; 03-22-2007 at 08:33 AM.. |
When I cleaned mine I used a plastic handle from my wifes duster. Like the one on a flyswatter!. Put a piece of paper towel thru the hole in the handle and it did a great job of drying out the inside and left no residual. Then put in sun or hair dryer for several minutes.
