Diving in 911
964 throttle body question
Anyone have an idea on what this arm is supposed to attach to? It a 964 3.6. It’s spring loaded arm that actuates a vacuum damper of some sort. Ther is nothing in line with the pull direction. Scratching my head over here…. Thanks!
1976 911s Special Edition Turbo bodied IROC tribute
2002 911 Carrera C4S
1971 914 1.7 Tangerine
1989 964 Coupe/1992 964 Cab
1987 928s4 Granite Green / 1986 951
Old 08-26-2023, 09:16 PM
Diving in 911
Originally Posted by rsscotty View Post
It is a vacuum actuator that controls the throttle plate in the tube below it. It is normally called resonance valve. Normally closed at lower rpm and open around 5300 via Motronic command.
Any idea where the arm is linked to? Thanks!
Old 08-27-2023, 01:20 AM
7.0:1 > 11.3:1 > 7.0:1
That arm doesn’t connect to anything.
Old 08-27-2023, 08:33 AM
Racer
winders's Avatar
That would be completely incorrect!
Look here:
Scott Winders
PCA GT3 #3
2021 & 2022 PCA GT3 National Champion
2021 & 2022 PCA West Coast Series GT3 Champion
Old 08-27-2023, 01:51 PM
Thats 993, not 964.
Look here:
Old 08-27-2023, 02:51 PM
The earliest 964 had 2 resonance flaps, later ones had only 1 flap but the vacuum actuator didn’t change. The photo is from Christophorus-May-1990. I have a pdf copy of the technical article that explains the resonance chamber, let me know if you’d like a copy.
Old 08-27-2023, 04:12 PM
Perhaps you mean early had two butterflies, one resonance flap? I wasn't aware that there were two flaps.
Anyhow for OP Tbone, the extra arm on the resonance flap shaft wasn't connected to anything.
993 top (1995)
964 bottom (1989)
Old 08-27-2023, 05:02 PM
Diving in 911
993 top (1995)
964 bottom (1989)
Thanks for saving me from going insane. 😆
Old 08-27-2023, 05:37 PM
The earliest design had 2 resonance tube flaps. The linkage for the “slave” flap was connected to the lever the OP was concerned about. I’ve read about the original design when preparing to change all needle bearings and seals in my throttle body but I cannot find the documentation. Finally it does not matter because there is only 1 resonance flap in his throttle body and there is nothing connected to the lever. Same as mine.
Old 08-29-2023, 12:55 PM
Thanks for the education 540964. Looking closer now at your Chritophorus article I see the second flap, I didn't see it at first.
Old 08-29-2023, 01:15 PM
