Pressure Guage Wiring Question
I removed the vapor expansion tank behind the dash to replace the hoses and noticed a loose green wire. There is an unused spade connection on the oil pressure/temp guage. Should this green wire be connected to it? Car is a 1970 911T.
1969 912/6 Coupe 1970 911 T Targa |
C4 Pazzo,
I suspect your gauges all work OK. The green wire (no tracer color) is for the Sportomatic over-temperature warning light. The good news is you can use this wire for a low-pressure oil warning light that was not original in your (S-instrument) 911. Best, Grady
ANSWER PRICE LIST (as seen in someone's shop) Answers - - - - - - - - - - - - - - - - $0.75 Answers (requiring thought) - - - - $1.25 Answers (correct) - - - - - - - - - - $12.50 |
Thanks, Grady, for your speedy response. I'll leave it disconnected for now, but I suspect there is a low-pressure oil warning light mod in my future.
Back to connecting vapor hoses!
