VW Part number for master cyinder switches?
I am replacing my master cylinder light switches because the brake light on the dash will not go out. The Porsche part number is 113-945-515G-M323. I've been told that VW sells the same switch for much less. Anyone know the VW part number?
vwc-113-945-515-g 3prong
vwc-113-945-515-h 2prong they should be about $5. |
Thanks.
If you've done any work on the brake system that trips the warning light, you have to reset it by disconnecting the battery. Just thought I'd ask the question in case you haven't tried it yet.
I tried the John Walker method of removing the pos battery terminal with the ignition on. So far the light hasn't come back on.
| All times are GMT -8. The time now is 02:11 PM. |
