rs6er's Avatar
Send a message via AIM to rs6er Send a message via Skype™ to rs6er
VW Part number for master cyinder switches?
I am replacing my master cylinder light switches because the brake light on the dash will not go out. The Porsche part number is 113-945-515G-M323. I've been told that VW sells the same switch for much less. Anyone know the VW part number?
John
Original owner '81 911SC blackmetallic coupe. Terbatrol, SSI, M+K Gen 4, SC+ cams, A/C delete, console delete, heater backdate, 7 & 8 x 16 Fuchs with polished rims, Turbo tie rods, tensioner update, Rennline engine mount bar, Mainely Custom sump plate, new top-end, corner balance.
Old 03-24-2007, 01:37 PM
vwc-113-945-515-g 3prong
vwc-113-945-515-h 2prong
they should be about $5.
Old 03-24-2007, 06:16 PM
rs6er's Avatar
Thanks.
John
Old 03-25-2007, 06:00 AM
david914's Avatar
If you've done any work on the brake system that trips the warning light, you have to reset it by disconnecting the battery. Just thought I'd ask the question in case you haven't tried it yet.
David Dryden
'86 911 Coupe
'05 BMW X5 4.4i
Old 03-25-2007, 06:04 AM
rs6er's Avatar
I tried the John Walker method of removing the pos battery terminal with the ignition on. So far the light hasn't come back on.
John
Old 03-25-2007, 04:00 PM
