| Registered Join Date: Dec 2006 Location: Brentwood, California
				Pressure Guage Wiring Question
			I removed the vapor expansion tank behind the dash to replace the hoses and noticed a loose green wire.  There is an unused spade connection on the oil pressure/temp guage.  Should this green wire be connected to it? Car is a 1970 911T.
				__________________ 1969 912/6 Coupe 1970 911 T Targa | ||
|  03-24-2007, 01:50 PM |
| Registered Join Date: Dec 2003 Location: Arapahoe County, Colorado, USA
			C4 Pazzo, I suspect your gauges all work OK. The green wire (no tracer color) is for the Sportomatic over-temperature warning light. The good news is you can use this wire for a low-pressure oil warning light that was not original in your (S-instrument) 911. Best, Grady
				__________________ ANSWER PRICE LIST (as seen in someone's shop) Answers - - - - - - - - - - - - - - - - $0.75 Answers (requiring thought) - - - - $1.25 Answers (correct) - - - - - - - - - - $12.50 | ||
|  03-24-2007, 02:11 PM |
			Thanks, Grady, for your speedy response.  I'll leave it disconnected for now, but I suspect there is a low-pressure oil warning light mod in my future. Back to connecting vapor hoses!
|  03-24-2007, 02:35 PM |
