-   -   Help! Engine Speed Sensor Connector? (http://forums.pelicanparts.com/porsche-911-technical-forum/337654-help-engine-speed-sensor-connector.html)
david914 03-25-2007 02:05 PM
I've had some intermittent trouble starting my '86, particularly when cold, so I started checking around and found this
http://forums.pelicanparts.com/uploa...1174856478.jpg
This is the connector for the engine speed sensor. The left-most connector pin in the pic is mangled as though it wasn't seated properly and forced into place.
I suppose it's safe to assume this could be the source of my problem? The head temp sensor checks out fine per ambient and running measurements.
If nothing else, I need a replacement connector pin. I'm hoping our host has them. Going to look now...
Jeff Alton 03-25-2007 02:21 PM
kayjaco and eagle day both sell the connectors and pins. I don't think Pelican sells them but I could be wrong.
Cheers
