david914's Avatar
Help! Engine Speed Sensor Connector?
I've had some intermittent trouble starting my '86, particularly when cold, so I started checking around and found this
This is the connector for the engine speed sensor. The left-most connector pin in the pic is mangled as though it wasn't seated properly and forced into place.
I suppose it's safe to assume this could be the source of my problem? The head temp sensor checks out fine per ambient and running measurements.
If nothing else, I need a replacement connector pin. I'm hoping our host has them. Going to look now...
David Dryden
'86 911 Coupe
'05 BMW X5 4.4i
Old 03-25-2007, 02:05 PM
Jeff Alton's Avatar
kayjaco and eagle day both sell the connectors and pins. I don't think Pelican sells them but I could be wrong.
Cheers
www.turn3autosport.com
Old 03-25-2007, 02:21 PM
