PeterCarrera84's Avatar
Send a message via Yahoo to PeterCarrera84
Front suspension adjustment bolt is....
broken off. Where would I find such bolt ? here is a pic
I found out when checking heights , passenger side a bit higher , took a few turns to loosen, then I looked on the other side to compare, no bolt end broken off.
84 911 Carrera SOLD not forgotten
01 911 C4 factory Aerokit
76 914 rust bucket SOLD !!
03 Boxster S sold
98 944 S2 G Red,sold 04 FRC red Vette
Old 03-25-2007, 03:32 PM
Pcar dealer. Not sure if this is a special bolt. Don't think so.
Sherwood
Old 03-25-2007, 03:41 PM
randywebb's Avatar
the "adjusting screw" is a special square headed, angle tipped bolt that was blessed by Martin Luther before he decided to use a nail to post his witticisms on the church door....
- try a junk yard or count out a couple of twenty dollar bills FOR EACH ONE
"A man with his priorities so far out of whack doesn't deserve such a fine automobile."
- Ferris Bueller's Day Off
Old 03-25-2007, 03:49 PM
Chuck Moreland's Avatar
Note your crossmember is also broken, right were the screw head is supposed to pass through.
Looks like the screw hooked something and ripped off, taking part of the crossmember with it.
That little missing piece of crossmember is the only thing that keeps the adjusting cap from sliding off the torsion bar, so it really is important. You should replace or repair your crossmember.
Chuck Moreland - elephantracing.com - vonnen.com
Old 03-25-2007, 04:07 PM
+1 on the cross member note.
You can source the adjuster bolt and cap all for about $25 from Parts Heaven here in Hayward. They shipped me one to my door in two days.
-Chris
1987 Guards Red Targa (sold)
2006 Toyota Tundra DC 4x4, the "man-e-van"
1998 CR500
Well on the fringe......
Old 03-25-2007, 04:40 PM
Good eyesight Chuck.
Old 03-25-2007, 04:48 PM
+2 w/Chuck.
You should check the entire cross member. It looks like something hit that spot and sheared off the head of the adjusting bolt and could possible - at the same time - crack teh cross member.
Old 03-25-2007, 04:56 PM
Nine9six's Avatar
Parts Heaven
http://www.partsheaven.com
Good luck to you.
If it flows, it goes. If its smooth, it moves. Any questions?
96 993 C2 (Current)
87 911 Factory Turbo-Look Cab (Sold)
85 911 Factory Turbo-Look Targa (Gone)
Old 03-25-2007, 05:04 PM
tdatk's Avatar
+3 on Chucks advise.. That tbar retainer, when unsprung ( on a jack or on the track) without that adjustment screw CAN FALL OFF very easily. Replace the cross member.
Tim
82 SC
90 C2
Yasowatt
Old 03-25-2007, 05:06 PM
Chuck , thanks for the heads up on this. You guys and this forum are truly incredible !!!! my hat goes off to you ALL.
What is involved with the cross member,? and how could this have happened? and not feel it? mmmm
thanks again, Chuck. I will have to call a Porsche garage, and ask.
thanks again, regards, Peter
03 Boxster S sold
Old 03-25-2007, 06:57 PM
Grady Clay's Avatar
For those with eyes not as sharp as Chuck's, here is what is missing.
There is a part of the cross member between the red arrows that
captivates the adjusting screw. Without that broken piece in
place, the entire adjuster and screw can come off the end of the
torsion bar. This would result in the suspension colapsing.
Best,
Grady
ANSWER PRICE LIST (as seen in someone's shop)
Answers - - - - - - - - - - - - - - - - $0.75
Answers (requiring thought) - - - - $1.25
Answers (correct) - - - - - - - - - - $12.50
Old 03-25-2007, 07:15 PM
Al S's Avatar
Here's a fix for your X-member;
Al Shkuratoff
86 Carrera, SW chip, Fabspeed, M&K
83SC Platinum - Sold
83SC Slate Grey - Sold
Old 03-25-2007, 11:32 PM
randywebb's Avatar
nice
looks like this a weak point & we should inspect it periodically
Old 03-26-2007, 01:28 PM
Senior Member
Superman's Avatar
Mine broke when I decided to take a drive through a ditch. A local welding shop did a nice job of repairing it for about $10 or $15.
Mocha 1978 911SC. "Coco"
Old 03-26-2007, 02:07 PM
The local Porsche garage said it could be up to 2 hours work at 90.00/h to weld and replace the bolt. ofcourse it tepends how quickly they can get the bolt off. the welding shop sounds like a better deal!!
thanks, I will cancel my appt with the garage. !!!
thanks again,
peter
03 Boxster S sold
Old 03-26-2007, 03:24 PM
