I understand the 911 is oiled cooled but how and where is the air cooling the engine?
Administrator
The engine's cylinders and heads have heat-dissipating fins. The main engine blower (a fan) pushes air over and through those fins. On top of that, there is an oil cooler mounted near the engine case (and sometimes also one in the front right fender). The main fan also pushes air through the engine-mounted oil cooler.
Technically, the engine is both air- and oil-cooled.
Jack Olsen 1972 911 My new video about my garage. • A video from German TV about my 911 |
I have never seen estimates of how much heat is dissipated by the oil circulation/coolers versus direct heat transfer to the large amounts of air forced around the cylinders (w/cooling fins) by that large fan on the rear. I bet some of the real experts have some pretty good data on this
Richard Lane 1978 911SC 1973 "Clean" RS clone |
see ..Jack beat me too it and he IS rather more experienced.....
Stranger on the Internet
The oil is cooled by air also. Without delving into approach regarding crossflow heat exchangers, you can quantify with this:
Heat rejeced = 1.08 x CFM x Temperature differential Airflow over the engine from the fan x 1.08 x (air temp difference) air temp into the fan - air temp leaving the fan. Tough to measure precisely this last quantity without burning your hand holding a thermometer under the engine. Indirectly, you could do some more rigorous calcs with the engine as a control volume...heating value of fuel x fuel consumption rate x displacement x time -heat out the exhaust pipe will leave the actual quantity of heat being transferred by the cooling system. Oh, and don't forget the oil...500 x GPM x delta T (oil temp in and out of the cooler).
Patrick E. Keefe 78 SC |
I understand upgrading to an 11 blade fan would help to cool the engine and adding an extra oil cooler up front; how can I vent more air into the engine bay and expel the hot air. Thought about removing the engine lid grill.
I think there was just a thread on how the 11 blade fan didn't improve things that much. The oil cooler up front is key. It's nice to have a fan up there as well during heavy traffic.
Tom Hutchinson 80 Targa / 81 Coupe / 71 Targa (in Porsche heaven) My Garage Build: https://youtu.be/H0n_NwEQVbs "If one does not fail at times, then one has not challenged himself." Ferdinand Porsche |
Administrator
![]() Quote:
And the factory front-mounted oil coolers do a great job, too. Depending on your motor, a Carrera's cooler might be needed for track use.
