twobone's Avatar
is this the correct hose?
I need this hose to run from the stock heat exchanger on my SC, up through the hole in the body and into the blower motor on the top left of the motor:
911-211-522-00-M260
Heat Exchanger to Blower Motor (Length, 105.4cm X 6cm I.D.), right, 911/911 Turbo (1975-89), without A/C
I need at least 30 inches in length to reach the blower motor
Garage is empty
Gone:96 TVR Chimaera, 05' Mazdaspeed MX5/89' Caterham Super Seven/84' Carrera/81' 911 SC targa/74' MGB
Old 03-28-2007, 11:26 AM
I think the part you have there is the long hose that runs from the blower over the top of the shroud/fan and down thru the right engine tin opening to the HE.
If you are looking at 30 inches you may be looking for the hose that runs from the blower to the engine tin on the left rear corner. On my 78 it clamps to the metal there. A separate short hose runs between the engine tin down to the HE
Richard Lane
1978 911SC
1973 "Clean" RS clone
Old 03-28-2007, 05:38 PM
