WydRyd's Avatar
Question Spark plug gaps with aftermarket ignitions?
Anyone have any first hand experience with setting spark plug gaps using aftermarket CDI units (MSD or Crane) in a forced induction application?
Please see:
http://forums.pelicanparts.com/911-930-turbo-super-charging-forum/326382-plug-gaps-aftermarket-cdis.html#post3200373
Merv
'89 911 Turbo Cab
Protomotive MAP ECU, Twin Plugged Heads, GT2-EVO CAMs, 3.3L fully finned P&C's, ARP fasteners, C2T head gaskets, Titanium Retainers, Turbo spec valves, springs & guides, 964 splash valves, GT35R BB turbo, GSF Stainless Headers, Magnaflow Exhaust, Full bay Intercooler, TiAL 46mm w/gate, TiAL 50mm BOV, Apexi AVC-R EBC, SPEC Stage3+ Clutch kit, Crane CDI Ignition
Old 04-05-2007, 01:35 AM
I'm not going to comment on my gap as it's not a turbo like yours. Greater combustion psi demands greater spark energy vs mine. The greater the load on our close dizzy cap contacts the greater the chance of a crossfire among them. I know nothing of turbos.
i'm only good for suggesting you have very good CD positive and negative with dielectric.
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 04-05-2007, 05:18 AM
WydRyd's Avatar
Thanks Ronin. In natural aspiration applications, plug gaps of 0.040-0.045" can be used, but in forced induction configurations, obviously the plug gaps have to be reduced to reduce the likelihood of flame blow-out.
The honda ricer guys who run 19+ psi boost, set their gaps to 0.029-0.030", so I guess that may be a good guide for me.
The factory recommends 0.6mm to 0.7mm for stock 930 turbo's with stock boost and ignition. With aftermarket CDI, I should be able to open up the gap by up to 0.005", so that would take me to ~ 0.032". Hopefully even with higher boost.
I was just hoping someone on this board would have first hand experience with these things
Merv
'89 911 Turbo Cab
Old 04-05-2007, 03:51 PM
I'm with Bill
Rick V's Avatar
In your aplication I'm not sure, but with the NA stuff .45 is too much. With an MSD unit and the gap of .45 the rotor has a tendancy to burn out.
Old 04-05-2007, 05:12 PM
T77911S's Avatar
call the manufacture. they know their system best and what it can do.
88 BMW 325is 200K+ SOLD
RACE CAR:: sold
Old 04-06-2007, 07:17 AM
