Torque Specs
What are the torque specs for 2.2 911:
Valve cover nuts sump plate nuts drain plugs Thanks in advance, Rob
356robo 70 T Targa Looking for a 2.2,2.4, or 89 coupe |
turbo valve covers- 8Nm or 5.9 ft lbs
hope that helps |
Re: Torque Specs
Per Wayne's book-
sump plate nuts--M6, 11Nm (8.1 ft/lbs.) drain plug in sump--M22x1.5, 42Nm (31 ft./lbs.)
Tom Tweed Early S Registry #257 R Gruppe #232 Rennlist Founding Member #990416-1164 Driving Porsches since 1964 |
Somatic Negative Optimist
That doesn't sound right.
Wayne's book says that but.....................the Valve cover nuts are M8 and the sump plate nuts are M6. The M6 cannot get more torque than the M8, something is wrong. I'll buy the 6-8 ft-lbs for the sump (M6) but the valve cover (M8) is more like 12-18 ft-lbs. A lot of times the sump plate gets warped from over-torqueing. Straighten the plate first, apply the new gaskets, start with an easy 6-8 ft-lbs. Install the sump plate so that the pick-up for the pump is not impaired; plug on the left. Valve covers: With only 6 ft-lbs, the Alu crush washers wouldn't even seal. Use ~12 ft-lbs at first. Watch both sump and valve covers for leaks. You can always tighten more if it leaks. Another issue is that a torque wrench for ft-lbs is not accurate in the very low range; your'e getting into inch-pounds for M6. Cheers.
1980 Carrerarized SC with SS 3.2, LSD & Extras. SOLD! 1995 seafoam-green 993 C2, LSD, Sport seats. ![]() Abstract Darwin Ipso Facto: "Life is evolutionary random and has no meaning as evidenced by 7 Billion paranoid talking monkeys with super-inflated egos and matching vanity worshipping illusionary Gods and Saviors ".
