Bouncing Tach
Off and on my tach would start wigging out. I did a search and it seems that the alternator or voltage reg. would be the most likely culprit. Now, is checking the VR as simple as checking the volts reading on the battery and check for a flucuation there, or is there another way. Also, where is the VR? Is it in the Alt. held in by 2 screws as it is on my Mercedes? It is definetly the wrong time of the year to be laying the car up for maintenance.
The "collection" 1983 911 SC Targa (1 of 1430 imported) 1994 MB E320 Coupe (1 of 825 imported) 1992 MB 190E 2.6 2004 Volvo V70 2.5 Turbo (1 of a bazillion imported) ![]() |
Assuming you are talking about the 83SC the regulator bolted to the relay pannel in the engine bay. To check measure the voltage across the battery while you ref the engine. It should go up to somewhere around 14.2 volts and stay there as the revs go up. If it keeps raising much more you found your issue.
These tachs have some oil in the shaft bushings of the tach needle that acts like a mechanical dampener. Some tachs "dried out" and are more bouncy than others. They overshoot. I replaced mine once on the 74. Another reason could be a poor connection on the 14-pin connector in the engine bay. It is on the relay panel. Good luck, Ingo
1974 Targa 3.6, 2001 C4 (sold), 2019 GT3RS, 2000 ML430 I repair/rebuild Bosch CDI Boxes and Porsche Motronic DMEs Porsche "Hammer" or Porsche PST2, PIWIS III - I can help!! How about a NoBadDays DualChip for 964 or '95 993 |
It's a sickness really...
I had the same tach problem and decided to swap the regulator first because that meant less down time than an alt rebuild. My DMM at my battery showed crazy readings between 9v and 17v.
On my '82 the reg was attached to the backside of the alt. I bought a new reg from our host: 911-603-913-01-M262. It was obvious when I pulled the old reg that it was worn beyond being useful. Since the new regulator install, no more tach bouncing...no more super-bright headlights that raise and lower with my RPMs. Also installed a volt meter at the same time... Good luck!
'88 Carrera Targa (Venetian Blue) '08 Mini Cooper (Blue w/ white top) '91 Honda CRX Si (white 100% stock) '65 Mustang (cream - dressed as a GT350) |
The 911 was converted to an internal regulator in 1982. Search here under "early_s_man" for the original tech bulletin, it will guide you.
'66 911 #304065 Irischgruen ‘96 993 Carrera 2 Polarsilber '81 R65 Ex-'71 911 PCA C-Stock Club Racer #806 (Sold 5/15/13) Ex-'88 Carrera (Sold 3/29/02) Ex-'91 Carrera 2 Cabriolet (Sold 8/20/04) Ex-'89 944 Turbo S (Sold 8/21/20) |
Dancing Tachomoter
Before you do anything, check the ground strap from the battery to the body and make sure the battery post connectors are tight. Then check you voltage output under various scenarios, if there is a constant voltage with minor variations, your regulator is fine. Check the battery as well. This is cheaper and less time consuming than pulling the alternator with a built in regulator.
AutoBahned
it could also just be under damped
but the grounds, etc. need to be cleaned every few years anyway |
I wonder if anyone has successfully fixed the damping action as a DIY as apposed to sending it to NHS? I would love to take this on myself, but would rather not go in blind.
'80 RoW 911 SC non-sunroof coupe in Guards Red It's not a Carrera.... It's a Super Carrera! |
do you still have points? Or is this electronic dizzy.
1973 911S (since new) RS MFI specs 1991 C2 Turbo |
Six year old thread. And the VDO tach movement does not get "under damped" the damping is in the inertia of the movement. Take one apart if you don't believe me. The mass of the movement does not change over time, I have 45 year old tachometers that work perfectly.
AutoBahned
nonetheless, NHS can increase the dampening (not that I said the dampening was caused by anything at all...)
it is good to revive old threads as they have information in them that is potentially useful (similar to restoring old cars?) Last edited by RWebb; 09-27-2013 at 03:42 PM.. |
Thread Tools | |
Rate This Thread | |
