Crotchety Old Bastard
RarlyL8's Avatar
BUMPER MOUNT - What is missing in this picture?
I am in the process of replacing (temporary) my FG bumper with a stock bumper. All of the body work was done at once on this car about 10 years ago and lots of stock parts hit the garbage can.
Fast forward to now and I can't remember how the stock bumper mounts to the car. There is a place in the picture (below) for the bumper shock mount but the hole is way too big. I vaguely remember some sort of clip or bracket that went in that spot.
So what is missing in this picture?
Thanks!
Old 04-01-2007, 05:56 PM
group911@aol.co's Avatar
That would be the bumper shock. There are actually 5 parts to it. I starts at the left side of the pic with the self locking nut, then a rectangular flat washer, then a rubber grommet. Then, about halfway down the shock tube is a half round strap that holds it in. Make sense?
Thanks,
Bob
group911@aol.com
Old 04-01-2007, 08:48 PM
Monkey Wrench
Spede's Avatar
Old 04-01-2007, 08:58 PM
The rubber grommet is 3/8" thick. There should also be a plastic bearing around the threads of the stud that will ride in the hole.
Kevin
'87 Targa
Old 04-01-2007, 09:02 PM
RarlyL8's Avatar
The bumper shock pictured is all that I have.
Where can I find an exploded diagram (that is big enough to see) with the parts and part numbers I need?
What is the rubber strap for?
Old 04-01-2007, 09:35 PM
http://www.pelicanparts.com/PartsLookup/HTML/911_USA_78_83_KATALOG/802-05-Frame3.htm
Thanks,
Bob
group911@aol.com
Old 04-01-2007, 09:51 PM
bumper shocks
I may have a couple sets of them lying around. I replace the heavy bumpers w/ fiberglass. Let me know exactly what you need and I will look.
Speedo
Old 04-01-2007, 09:59 PM
RarlyL8's Avatar
Thank you for the diagram! The one I pulled up was identical but too tiny to see all the parts.
Loos like I need the entire shock-to-chassis parts list, #29-35
29) M12 nut
30) 13 washer
31) desk pad ?
32) stop
33) supporting bow
34) M8x20 bolt
35) A8 lock ring
More importantly I need a picture of the assembled part on a car. I cannot visualize how this supporting bow / stop assembly works.
Speedo - any parts you have are appreciated.
Old 04-02-2007, 06:06 AM
