911 SC CAB
Guest
Posts: n/a
problem: Idle around 2000 only on warm start
Hello,
I was hoping on getting some advice on a problem I have encountered recently. I have an 83 911 SC Cab...In the cold morning, the car starts fine, idles normally...
After I drive to get coffee, however, at the local Dunkin Donuts ( about 5 minutes from my house), I get in my car, start the car, and the idle stays at 2000 RPMS....
After I drive for 1/2 hr and the temperature goes to normal operating temp., then at the stop light, the idle is normal again...at 900 RPM...
Could I have a faulty Auxiliary Air Valve?
Hopefully someone with a similar problem can give me some advice. Thanks in Advance.
Old 01-17-2001, 07:27 PM
lagoon
Guest
Posts: n/a
I think you are right. check the AAR.
Old 01-17-2001, 07:30 PM
911 SC CAB
Guest
Posts: n/a
How do I check that valve. I located it in the engine bay but now what? Thanks.
911 sc cab euro
Old 01-17-2001, 07:33 PM
