-   -   79 3.0 - dropping idle (http://forums.pelicanparts.com/porsche-911-technical-forum/339353-79-3-0-dropping-idle.html)
twobone 04-03-2007 06:00 PM
when I rev the engine and let off, the revs drop to an almost stall, then return to idle.
any ideas?
Joe Bob 04-03-2007 06:39 PM
Try turning the idle up....if it does it only when warm, you may have a vacuum leak or a airbox leak....
Do you have a pop off valve in the air box?
twobone 04-03-2007 06:48 PM
no pop off valve
Hi
No pop off valve
twobone 04-03-2007 06:49 PM
running problems
last summer it was having hot start problems
Could it be related to fuel pressure accumulator issues?
Joe Bob 04-03-2007 06:52 PM
Hot start can be pressure valve in the neck of the fuel pump....cheap part. The idle is a different issue.....could be fuel pressure related....you need a CIS gauge to test it.
