3.0 track car running lean - what are my options?
Just had my stock 82 SC dyno'd to start racing with NASA and found out my AFR is 14. Someone mentioned that Andial makes a non-turbo fuel enrichment system. Does anyone know about it? I've ready plenty about it for turbos but not a 3.0. Any other options? I'm afraid my engine is going to melt.
Sean
1982 SC D-Stock #372
NASA GTS2
1971T restoration in progress, read about it here:
http://911restorationmadness.blogspot.com/
Old 04-04-2007, 09:16 AM
Sean:
For sure, 14:1 AFR is FAR too lean at WOT for engine longevity.
The very first thing I'd suggest would be to install the CIS fuel pressure gauges and see where your control & system pressures are. That will determine your next course of action.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
porsche@rennsportsystems.com
www.rennsportsystems.com
Old 04-04-2007, 09:27 AM
Thanks Steve, will do.
Sean
NASA GTS2
Old 04-04-2007, 09:34 AM
Ferdinand Magazine
johndglynn's Avatar
Sean, I recently dyno'd my C3 and also came home with scary lean mixtures at the top end and 11bhp down on stock at 189 flywheel. I too figured it would be fuel pressure, as idle CO was spot on and was all OK up until about 4k revs, when the AFR curve dropped right off.
With no CIS gauges and only three days before a track event, I just had to get stuck into the system and see what I could find. I stripped most CIS stuff off the engine, cleaned it all out, found a few vac leaks, a duff connection on my WUR and a small fuel leak by the accumulator. I put it all back together, was definitely stronger so I redyno'd.
Now read 202bhp (flywheel extrapolated), with more in the mid range, but AFR at the top end was exactly the same. I had three hours to spare so I dropped the fuel pump and found a pinhole leak by a copper washer at the pump banjo - tiny bit of corrosion in there. Cleaned it all up and wow totally different. Not dyno'd it again yet, but it has given me lots more up top and am sure it has solved the problem. I took it easy on the day just in case, but I think we are home free - good job too as '76 C3 fuel pumps are silly money!
Good luck tracking down your problem, least you know it is an issue now rather than finding out the hard/expensive way.
Sheriff at www.impactbumpers.com
Brand support at classicretrofit.com/tuthillporsche.com
1976 Porsche 911 Carrera 3.0: 'The Orange' - 1981 924 Turbo - 1983 944 Lux - Too many BMW motorcycles
Old 04-04-2007, 10:26 AM
Originally posted by Steve@Rennsport
Sean:
Steve - my mechanic is investigating, but I'd like to get more handy with the CIS system (yes I must be insane). Is a pressure gauge like this one from our host up to the job of testing the fuel pressure or do you use something different?
http://www.pelicanparts.com/catalog/shopcart/TOOL/POR_TOOL_CAT447_pg21.htm
Sean
NASA GTS2
Old 04-05-2007, 04:53 AM
