efhughes3's Avatar
Simple engine drop question....
I'm getting ready to do a drop tomorrow on my '84. This will be my second, and I'm gonna try the motor alone. Since I have the mid-rise left, I think it will be simpler to remate the two pieces when it goes back in. You only live once, right?
At any rate, I think I've got it all ready to come out. I was looking at the checklist for the drop in the tech info center here, which is also for an engine only drop. Two of the steps are:
- Disconnect starter wires
- Disconnect back-up light
If I'm leaving the tranny in, why would I need to unhook these?I'm assuming the trans will droop some when the motor comes out, and I'll support it, but it doesn't seem like it could come close to exceeding the slack in the wires for these connections? Am I off base in this thinking?
Ed Hughes
2015 981 Cayman GTS
6 speed,Racing Yellow
Past:1984 911 Targa (Ruby), 1995 993C2 (Sapphire), 1991 928S4
Old 04-06-2007, 10:37 AM
Slumlord
Porsche_monkey's Avatar
I think the yellow wire on the starter runs back through the engine area. I just had to take it off to seperate the engine and tranny. I guess the battery lead could stay on.
I'm not sure about the back-up switch.
84 Cab - sold!
89 Cab - not quite done
90C4 - winter beater
Old 04-06-2007, 11:02 AM
mschuep's Avatar
you have to disconnect both when doing motor alone.
-Matt
1985 Targa
Old 04-06-2007, 11:08 AM
efhughes3's Avatar
Why?
Ed Hughes
2015 981 Cayman GTS
Old 04-06-2007, 11:11 AM
efhughes3's Avatar
Sorry, looked at them, I see why on the starter, but the backup, I don't uderstand.
Ed Hughes
2015 981 Cayman GTS
Old 04-06-2007, 11:30 AM
efhughes3's Avatar
Figured it out, I was spaced out and looking at the speed sensor, confusing it as the backup. Ready to drop....
Ed Hughes
2015 981 Cayman GTS
Old 04-06-2007, 11:54 AM
mschuep's Avatar
sorry I didn't respond, glad you figured it out!
BTW, I've done engine alone before, I think you will find that re-mating the trans and engine is not all that difficult. good luck
-Matt
1985 Targa
Old 04-06-2007, 12:27 PM
rallyracer's Avatar
Re: Simple engine drop question....
go for it and let me know how it goes. i have the midrise and ATV jack also, so i'm curious. personally, with those 2 tools and a floor jack for the tranny, it's so easy to r&r both together that the thought of trying to mate the input shaft and t/o bearing arm in the car makes me cringe.
enjoy.
david
1983 911SC-Sold!
Old 04-06-2007, 01:40 PM
efhughes3's Avatar
I will see how it goes back in. This is the front side of an engine rebuild, so it will be out a while, probably a couple of months. One of the things that also figured into this is not having the transmission underfoot in the garage while I'm working on the engine.
The way I figure it, the worst thing that can happen is I have to pull the trans. Who knows, I met get bored waiting for stuff at the machine shop, and do it anytway. When you think about it, many Porsche shops pull the engines only for clutch jobs, etc, it can't be THAT bad of a task mating the two together with the tranny in the car.
Ed Hughes
2015 981 Cayman GTS
Old 04-06-2007, 03:46 PM
Redundant warning...Be sure the battery is disconnected before
proceeding.
Mike B.
'72 911E Coupe
Early "S" #1065
Old 04-07-2007, 08:22 AM
Czar of C.R.A.P.
dfink's Avatar
Double warning make sure the throttle linkage is disconnected from the tranny bell crank to the engine bellcrank. It can stay connected with the two attached. If it is like my 85 you have to take tham Dang little clip off the ball socket at the top bell crank.
66 912 Coupe
84 Carrera Cab Hardtop HC3.4 Hyper Carrera
2005 Dodge Magnum 5.7 HEMI
Cabriolet Racing And Performance C.R.A.P. Gruppe #1
Put on some C.R.A.P. and drive....
Old 04-07-2007, 09:51 AM
efhughes3's Avatar
That stuff was all done prior....thanks for thinking of me, however. The engine is out.
Ed Hughes
2015 981 Cayman GTS
Old 04-07-2007, 03:02 PM
