kdubb's Avatar
Cold Start problems need help
Ok, I have changed the plugs (Bosch Platinum), New Distributor and Rotor, had the Fuel injectors checked (no problems), and new o-rings for fuel inj. I have checked and have spark and fuel however, the car will not start cold. The car did sit with 3/4 tank of gas for atleast 5 months. Could it be the gas? However, I have had to use starter fluid to get it started, but when it is running, it runs fine.
Please help. 1985 911
Old 04-05-2007, 05:46 PM
kdubb's Avatar
anyone?
Old 04-05-2007, 05:56 PM
kdubb's Avatar
Question
bump
Old 04-06-2007, 05:03 AM
Search for (csv) cold start valve checks , and make sure frel pump/check valve are good. fact that st fluid gets you going says that fuel delivery is an issue . Bentleys manual gets you through all of it.
HB Kramer
(4 sneaks and 6 airheads): 79 911SC Coupe (sunroof delete)
(2 sneaks and 2 airheads): BMWS: R12GS(a) R90S, and some old British iron as well.
Old 04-06-2007, 05:27 AM
