3.2 injector flow rate needed
does anyone know the flow rating on stock 3.2 injectors?
Thanks |
flow rate of 84-86 injector is 22# per hour. 87-89 may be the same..or very close.
Do you know if the flow rate was based on a standard fuel pressure of 3.0 bar(43.5 psi) or Carrera fuel pressure which is much lower?
Joe |
Bosch #0 280 150 951 346cc/min 33.9lbs/hr 69.2est hp ea 300kpa test pressure
Bosch #0 280 150 201 236cc/min 23.1lbs/hr 47.2est hp ea 300kpa test pressure I do have some others How'd you access that post? |
Bill,
Do you have the flow rates for Bosch # 0 280 150 158 @ 300kPa? I did a search on injector flow that took me to this post. A great tool for researching technical data that cannot be found anywhere else. Joe |
Sorry, no info on that one.
I had Carrera injectors measured at ~230cc at 300kpa. Not certain which ones they were, but I am reasonably confident they were 158s. They were having trouble supporting 250hp on my engine without excessive fuel pressure, so I stumped up for 803 (944 Turbo) injectors.
I gave the part number you list a quick search and came up with this (extensive) list. Note that there is some variance in the test pressure and that some (eg the 158s) don't have a test pressure. http://www.telusplanet.net/~chichm/tech/injectors.pdf My 803s tested around 330cc at 300 kpa, for reference. |
My listing for the 944t is
Bosch 0 280 150 811 298cc/min 29.2lbs/hr 59.6est hp ea 350kpa test pressure don't know what year this one might be of interest to someone Bosch R Sport Bosch R 280 410 144 434cc/min 42.5lbs/hr 86.8est hp ea 300kpa test pressure |
I found that LT1 Multec injectors PN 1709004 with a flow rate of 24 lbs @ 3 bar (43.5 psi) work very will on my 86 3.2 in case anyone is interested.
They seem to enhance performance all around particularly, low end and result in a very smooth idle too. Cheers, Joe |
These Corvette injectors are the ones I'm using:
I suspect the 28 lb injectors would be even better. The reason I feel this way is because our stock 3.2 injectors which are rated at 22lbs are most likely rated at stock Carrera fuel pressure of 36psi which is quite a bit lower than the standard 43.5psi that the LT1 injectors are rated, so as soon as I can get a hold of some I'll let you know. Here's a set that I've been considering: or Here's a picture of a Bosch and Multec injector side by side: http://chevythunder.com/fuel%20injection%20mech.%20pg%20B1.htm Cheers, Joe |
| All times are GMT -8. The time now is 05:36 AM. |
