-   -   Frame integrity on old 911s? Rust out problems? (http://forums.pelicanparts.com/porsche-911-technical-forum/34001-frame-integrity-old-911s-rust-out-problems.html)
ebenstein 01-20-2001 10:36 AM
I have a deal brewing for another 911,its a 73 coupe and is infair condition at best. It has a pretty good bit of rust in places like the door jams and such but I am more concerned with the under carige IE the frame structure and any important areas of attention I may need to look at before getting into something I may not want to take all the way to completion. Can anyone offer there insight on this subject before I make a mistake here. I should note that the seller is only asking 2,000 for the car and it does run.
Kenneth
kenneth@carwrecks.org
Early_S_Man 01-20-2001 10:56 AM
Kenneth,
The '73 models had a pan that was galvanized up to the door sills. That is good for some protection, unless, of course, it has been used in winters with salted roads! As our good friend Jeff in Hawaii (Rufblackbird) has found with his '76, even a 100% galvanized shell is not weatherproof in a salty, humid atmosphere after 25 years!!!
Warren Hall
1973 911S Targa
dtw 01-21-2001 02:09 AM
Kenneth,
Speaking from grave experience, you should be very careful before committing to this car. If you are seeing rust in the door jambs, odds are the longitudinals are rotting out while I type. Megabucks to repair correctly. Also remember that whatever rust you see is just the tip of the iceberg.
-Dave, 72 Coupe tub now sitting naked in my garage for a month or two of final body prep...
Dave
1972 911T (E motor) RSR replica project
http://members.nbci.com/dtwinters/garage/
