Wer bremst verliert
JohnJL's Avatar
Westach 6-cylinder CHT gauge kit
I found the Westach products on another post but just found this set of items on Spruce...its a westach item but I hadnt found it on the actual Westach site (Westach also didnt answer my email queries.)
I've posted a question to Spruce, has anyone used one of these? Ability to monitor CHT on all 6 cylinders is ideal! I've asked them how the sensors are mounted. Anyone else use this?
CHT ENG ANALYZER KT 6CYL 18MM 10-17218 $173.05
WESTACH CHT P/N 2A1 10-01235 $48.95
WESTACH 6 POSITION EGT SWITCH 10-01266 $35.60
WESTACH CHT THERM 712-5WK 10-01226 $14.75
http://www.aircraftspruce.com/catalog/inpages/westcombos5.php
looks awesome if it can be adapted...
2007 911 Turbo - Not a toy
1985 911 Cab - Wife's toy
1982 911 3.2 Indiash Rot Track Supercharged track toy
1978 911 3.0 Lichtbau toy "Gretchen"
1971 911 Targa S backroad toy
Old 04-07-2007, 06:53 PM
diy83sc's Avatar
I was going to install a similar kit a few years back and recall 14mm plugs and the need for a 14mm kit. To install, you remove the washer from the spark plug and place the sensor/wire combo in place of it.
You should search the threads as well. I believe that a sensor on 2 and 5 are just as effective. One other note I read was that two cylinders are always going to be hotter - not sure why though.
Cheers,
Tony
Old 04-07-2007, 07:14 PM
Jeff Alton's Avatar
I would love a kit that fit our 14mm plugs. Especially at that price!
Cheers
www.turn3autosport.com
Old 04-07-2007, 07:28 PM
RETIRED
Joe Bob's Avatar
I had them build me a CHT with a volt meter when I took out the clock. Nice unit, "close" to looking like it's a VDO but for 1/2 the price. They also added a couple of idiot lights I needed for the 3.6 belt sensor.
2012 ML350 3.0 Turbo Diesel
Old 04-07-2007, 07:48 PM
shbop's Avatar
Wouldn't it be easier, and cheaper, to run a dual Pyro-guage? One sensor in each side's collector. Individual cylinder monitoring is either going to require speed dialing a knob, six guages, or an ecu that over-rides to display highest temp. by default.
Jon
Old 04-07-2007, 09:02 PM
9dreizig's Avatar
Send a message via AIM to 9dreizig
since I don't have my car here.. what size are our guage holes??
"Todd"
98 Tahoe ,2007 Saturn Vue
86 930 black and stock, 80 930 blue tracdog
91 Spec Miata (yeah I race a chick car)
"life"ll kill ya" Warren Zevon
Old 04-07-2007, 09:10 PM
Re: Westach 6-cylinder CHT gauge kit
Hi John:
I've installed that product on an airplane that I used to own,...
Good stuff,....(sensors installed under the spark plugs).
It was turbocharged so it was quite useful to keep track of CHT's during ascent & descent.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
porsche@rennsportsystems.com
www.rennsportsystems.com
Old 04-07-2007, 10:23 PM
Wer bremst verliert
JohnJL's Avatar
Hi Steve, thanks for that.
Mike, do you have a pic? Did you have Westach do the modifications?
Tony, I read in an archived thread about 2 and 5 being expected to be the hottest as they are "sandwiched" and in that same thread that 5 was sometimes the hottest perhaps due to the least airflow/evacuation room. I think that thread had the Westach reference.
Jon, I hear you, and you're probably right once I know which cylinder tends to run the hottest the gauge will probably spend 90% of its time there. Seems like a great idea though.
My first email to Westach actually asked if they could squeeze 6 dials into one gauge, motorcycle-style.
I broke my vernier calipers yesterday (stepped on it) but believe the 3 1/8 inch is the right size for the clock hole.
Old 04-08-2007, 01:31 PM
RETIRED
Joe Bob's Avatar
Here ya go....
Old 04-08-2007, 07:03 PM
