-   -   Fractured stud (http://forums.pelicanparts.com/porsche-911-technical-forum/340202-fractured-stud.html)
kimlangley7 04-08-2007 04:34 PM
Fractured stud
80 911SC
In the process of performing the stock exhaust system swap to SSI and M&K I broke the stud that holds the two large oil lines against the body. I have maybe 1/4 inch of the stud remaining.
Q: How is the stud "fixed" into the body? ie > can I use another stud remover and try to unscrew the last bit out?
Suggested remedy's?? http://forums.pelicanparts.com/uploa...1176075250.jpg
JohnJL 04-08-2007 06:57 PM
you should be able to drill and "easy-out" that. Let it soak in PB Blaster or similar overnight and tap on it periodically/douse again.
Jeff Jagusch 04-08-2007 07:01 PM
My guess?
I believe that the stud in the photo is a weld stud that cannot be removed by anything other than cutting off and rewelding/
Jeff
