Fractured stud
80 911SC
In the process of performing the stock exhaust system swap to SSI and M&K I broke the stud that holds the two large oil lines against the body. I have maybe 1/4 inch of the stud remaining.
Q: How is the stud "fixed" into the body? ie > can I use another stud remover and try to unscrew the last bit out?
Suggested remedy's??
Kim Langley
2012 Carrera / 991.1
80 911SC
97 C230
73 BMW 2002Tii
Old 04-08-2007, 03:34 PM
Wer bremst verliert
JohnJL's Avatar
you should be able to drill and "easy-out" that. Let it soak in PB Blaster or similar overnight and tap on it periodically/douse again.
2007 911 Turbo - Not a toy
1985 911 Cab - Wife's toy
1982 911 3.2 Indiash Rot Track Supercharged track toy
1978 911 3.0 Lichtbau toy "Gretchen"
1971 911 Targa S backroad toy
Old 04-08-2007, 05:57 PM
Jeff Jagusch's Avatar
My guess?
I believe that the stud in the photo is a weld stud that cannot be removed by anything other than cutting off and rewelding/
Jeff
Old 04-08-2007, 06:01 PM
